Item: AVS Model 5 Style wheels - HR Racing HR-109
Age: Unknown - came on car when i bought it
Condition: Good quality rims despite being a copy. Chrome has no signs of deteriation, same weight as stock s15 rims. Gutter rash on one of the rears
Price: $750
To Fit: S14, S15, R32, R33, R34, 300ZX
Contact: PM me or email [email protected]
Comments:
Fronts: 18x8in
Offset: +38
Tyres: Falken Ziex ZE512 235/40/18 50% tread, one has camber wear on very inside. (could swap tyres to get good mileage out of them)
Rears: 18x9in
Offset: +38
Tyres: Roadstone N3000 265/35/18 80% tread, even wear
Note: one of the rears has gutter rash all round. Not very noticable from standing distance
Edited by wegs
https://www.sau.com.au/forums/topic/236463-18-avs-model-5-style-wheels/
  • 1 month later...
do you know how much to post to melb 3163?
I have used pack n send in the past to ship wheels. If i wrapped these up in cardboard including tyres i would estimate shipping to be $120. Do you have any other couriers in mind?
Cheers
Wegs
