Item: HKS EVC electronic boost controller Version 3
Age: ? Probably a few years
Condition: Nice
Price: $180
To Fit: Any turbo car, external or internal gated settings
Contact: PM or through thread
Comments: Installation and setup manual will be posted on this thread or printed out to send
-Basically this was removed from my r34 gtr as i upgraded to a version 6. The in-cabin module was a little too boring for my like and i like flashy things.
-Dyno sheet provided to show how well it holds boost.
-Cosmetically its in a very nice condition with no real defects and the solenoid looks very clean and hi-tech compared to say an AVCR solenoid.
Item: Billion VFC Pro - Variable fan controller
Condition: Nice
Price: $150
To Fit: ?? Im sure most cars
Comments: Cosmetically in fantastic condition; comes with wiring loom
-Basically it works by controlling either your OEM electric fan to come on at a pre-set temperature or it can be used to control auxillary thermo fans.
-Great for traffic or track duties
Item: Nismo Edition NGK Iridium Plugs
Age: 800-900kms
Condition: Nice
Price: ??? 80bux
To Fit: Mildly modified turbo cars with usual bolt-on mods
Comments: Was installed when my car was complied 6months ago, I bought a set of IRITOP7's not knowing what i actually had installed and when i changed the plugs to my surprise i found these.
Part Number is: T7340-8
-Pics will be posted soon.
Item:Impul ECU for R34 GTR
Age:?? Few years
Condition:Excellent
Price: Open to offers
To Fit: R34 GTR
Contact: Best to PM me
Comments: Remap'd ECU tuned for boost increase from exhaust addition, no top speed cut. Basically like a mines ECU
-$2000 brand new
  • 1 month later...
    • I'm going to slap an old nismo logo sticker on my spare one and sell it to the land of the free for a thousand bucks
    • lol, probably should have read further!
    • Well - they have arrived.  And they are easy on the eye to put it mildly... These only have three bolts - but for a start there is a key that fits with vacuum like precision..  And as you can see by my ruler, the interface is large..   I listened to a podcast on HP Academy about Dan (KiwiCNC) and I'm more than comfortable he knows what he is doing. R35 Bearing assembly should arrive later today so can mock that up for a look. Can't wait to get these on and get some brake pressure logging too. IMG_3860.MP4
    • I would be very confident that they are the same parts (the 2 different SKUs). It seems very clear that you can drop the cam in the 2-way opening, or in the other opening. If you arrange it in the other opening in the same way that you see any other 1-way diff, ie, with the flat of the cam up against the 1° side of the opening, then it would work as a 1-way. It can only spread the ramps when driving forwards - cannot spread the ramps on overrun. It would then appear obvious that if you put the cam into the opening "backwards", that you would get the angled flats of the cam working onto the "points" of the 1° side of the opening, which would give you ramp spread in both loading directions. I do wonder if the forward direction of the 1.5-way config is equivalent to the forward direction of the 2-way, seeing as the cams are flipped and the angled surfaces on those would need to be the same on each side - AND - clearly when installed in either the 2-way or 1-1ay configuration they are not intended to work exactly the same (the ramp angles on the 2-way are 10° different between forward and backward, and the ramp doesn't exist in the 1-way config). 'twere me, I think I would rather actually have a set of rings that offered the 2-way with two different sets of ramp angles, say the 55/45 of the existing design and maybe a 45/37.5 combo for a less aggressive effect), AND another set of rings with a dedicated 1.5-way opening and a dedicated 1-way opening. The 1.5-way opening would actually have the steeper angle on the overdrive side that causes it to be less pushy than the forward drive angle, like you see in many other diffs. But really - if this Nismo thing is thought out properly and all those surfaces work on each other the way that they need to, who am I to argue?
