  • Replies 260
problem with sa car scene is its too full of big headed wankers, which makes things like SCS fail, because everyone takes the attitude of 'rice this, autosalon that'. if you dont have the right offset then how can you be in a car show?
SCS is(was) a good thing for Adelaide, admit it, any car show in Adelaide is a good thing and can only help the scene, the people in the scene is what lets it down.
+1
Thats so true. Everyones bagging out each other's car whinging about this that etc... people were complaining about the car scene dieing in Adelaide earlier this year and when something like this comes up everyone whinges about this and that AGAIN! Its not the organizer's fault that the car show is dieing more and more every year - its because everyone goes around bagging out the show and the cars; in turn making people less incline to want to go or want to enter! Its up to the car enthusiast community to provide the cars for the show AND attend aswell as spreading the words about it... NOT have the attitude of "oh my cars too good for SCS I'm not putting my car in that rah rah rah" + "oh I'm not going to SCS its crap compared with rah rah rah" + "Everyone dont waste your time at SCS its rubbish rah rah rah"...
I'm not pointing this specifically at anyone but more in general theres just too much bad mouthing this and that... wheres the love!?
i agree its most peoples attitide that wreck a good car show atmosphere,
but hey, its the way it going to be.....
thats the world today.
i never got to experience the car culture before it turned sour, hell, i have NEVER had the opportunity
to run any of my cars down the drag strip...
is this the way our kids are going to enjoy there cars?
this seems like the new school mentallity
^^ agree with the comments posted above.
20 bucks for a day out at glenelg, then if you get bored you can go for a drink or swim, and not get sunburnt or couped up in a tent like previous years, plus you get to hang out with your club buddies and check out the other clubs... i don't see any downsides to this event. It should be as good as AJD, if not better.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
