  • Replies 87
Wrecking a complete car in melb
r33 gtst series 2
sold items are:
headlights
bonnet
front bar + rio
driver side windows switch
center console and dash fashia
items avaliable are the rest of the car
engine and gearbox manual 80k km inc computer = $3000
front calipers and rear brakes and calipers inc discs ABS= $600
rear end complete abs = $500 inc clipers and brakes and cradle
cluster =$200
doors complete motor window and reg door hangle and lock= $260 each
rear window = $150
side 1/4 windows tinted dark= 80 each
boot lid inc spoiler = $200
3 inch exhaust from front pipe steel inc cat near new $400
18 inch gold pro N1 BLACK RACING rims with bridgstone s03 235 40 18 tyres with 60% tread on em $1000
rear tail lights = $200 pair
skyline garnish $70
rear bar = $80
complete boot carpet and side trims = $150
complete seats inc door trims = $400
mirrors = $50 each
parcel shelf = $50
interior carpet $80
seat belts = $ 150 set
roof linning = $60
sunvisors = $50 pair
front steering rack = $100
front k frame complete $150
front hub assembleys = $150 each side
left and right guards $ 100 each
side skirts $ 150 pair minor crack on one not on visable section
rear pods 400r i think $100 pair
indicator stalk = $50
steering coloum $ 70
panel cuts also avaliable
pedal box = $100
cluch cyclinder $ 70
brake cyclinder $70
brake booster $70
climate control unit $80
front floor mats $40
heater air con box complete $ 150
dash no air bags $80
steering wheel immac no airbag $60
condenser $50
if there is anything not listed just ask for it i will have it for sure
Pick up in reservior call 0402090079
all items must be sold all prices are negoable no stupid offers please want to make someting back on my loss
Mate do you have any of the following?
Fog lites
raditor
radiator support bar (front cross bar bracket)
a/c condensir
grill
front right fender
let me know
cheers
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
    • I forgot about my shiny new plates!
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
