again whats blowby, i thought it wasnt too bad to blow a bit of black smoke out the exhaust, thought it was just cause of the big bore piping that these cars have
whenever i'm at the workshop watching a car on the dyno waiting outside for mine to go on theres always a lot of smoke coming out under full load.
thanks
https://www.sau.com.au/forums/topic/23699-low-compression/#findComment-507326
Blow by is the gases going past the pistons during combustion, these gasses are circulated to the rockercover where they then get redirected, one way or another, to eventually be burnt again in the cylinders (if you dont fit a atmo vent catch can of filter).
If the rings are starting to wear a bit, blow by will increase, and it would be noticable when opening the oil filler that alot of air seems to be getting forced out. If there appears to be no air being forced out, 'usually' means the rings are ok.
Jimbo2000, the smoke you see from a dyno run is because the AF ratios are intentionally richer during power runs, which helps control detonation.
https://www.sau.com.au/forums/topic/23699-low-compression/#findComment-508227
how do u know that the compression was 125?
are u sure that the gauge is correct ? if they are all 125 the gauge mynot be right or the engine not normal temp .to check if its bottom end prob ( warn rings or pistons ) do a compression test note the comp on all cil then squirt a small amount of oil in the cil crank a few times then check comp again if it raises say by 10 psi or more u have bottom end prob ( warn rings more than likely )if it doest rise it means warn top end ( valves or valve seats ). the other way is to do a cil leakage test , this is how u do it : spark plug out install i tube with a threaded bit at the end that screws in to the spark plug hole car in gear handbrake on then put compressed air in to cil (150 psi ) and listen far air leaking ( bottom end or top end ) .
note most of the time if engine runs good makes good power doest use a lot of oil and u find low compression ( but all cil the same ) its your gauge or the method u are using not correct so dont panic if all the above are right .
https://www.sau.com.au/forums/topic/23699-low-compression/#findComment-508747
what they did when they did my test (wasnt paying too close attention so didnt get a good look at what the instrument actually was) they had the plugs out and inserted the probe thing with guage on top into each spark hole (real technical! :) ) and turn the key for about 2 seconds.
wasnt 125 exactly on each one but pretty close.
https://www.sau.com.au/forums/topic/23699-low-compression/#findComment-509235
standard compression for rb25det is 1.2mpa (12.2kg/cm2)or 171 psi ( apr) limit .9 mpa , 9.2 kg/cm2 or 129 psi . thats at 300 rpm lower rpm = lower comp.variance is 14 psi . rb26 is slightly lower .like 2% lower as it has a lower comp and runs much higher boost . jimbo if urs has a true 125psi u wouldnt have much power unless u run very high boost but i dont think it would be that low .
it would be hard to start if it was that low too ( like taking a few cranks to start it .
https://www.sau.com.au/forums/topic/23699-low-compression/#findComment-509583
    • Hey guys! Thanks for the feedback!    it’s got some basic mods currently but it’s been tastefully done  has a z32 Maf and a HKS Mushroom filter an old logo nismo strut brace, splitfire coil packs, braided turbo lines, turbo smart boost controller, walbro 450 fuel pump, sports cat and a reinik cat back exhaust, shock works coilovers, Greddy turbo timer, blitz FMIC, blitz BOV, hard race hicas delete, ebc brakes (front), excedy heavy duty clutch, Michelin pilot sport 4 tyres, and the 33 GTR wheels from memory. i have also had my mate 3D print a gas cap holder for inside the petrol flap haha but she’s very clean underneath (being a paint sprayer of 15 years I did not want to mess around with rust!) and she’s had thousands spent on maintenance over the last few years, she drives like a new car!  my future plans is to do an RB30 rebuild with a 25 head uprated turbo etc etc I’m hoping to start this next year, I’ve just opened a premises for my business so that takes priority at the moment! But overall I’m extremely happy with it!
    • I'm just being rude. The VQ was developed by Nissan Japan, but it comes from the time when Renault were....ruining what Nissan had been before. Just look at a Nissan Tiida, and tell me that you're not looking at a Renault. In fact, just look at a V series Skyline or Z33 etc and tell me that you're not looking at something Frenchified. I just see the VQ an emblematic of that. It is also a nasty sounding thing. I'm really glad I chose to stay RB and not put a VQ30 in when I did my car. As to the RB30 being Aussie.....arguably it's a bit Aussie.
    • That depends, if the French got it from the Japanese, its Japanese. Or, is the rb30 aussie? Also, wouldn't it be Vq for a junior variant?
    • As soon as the MAFs are replaced with ones that work properly, if the harness isn't ruined it should run perfectly immediately.
    • If you haven't already decided on a career, look at being a mechanic, engine reconditioning or mechanical engineering. All 3 will give you different views and levels of knowledge (eg, mechanic is general for the whole vehicle, reconditioning will teach you engine specifics, engineer can design stuff). Or.......find something you love doing, hope its a well paying area and pay someone else to build the car for you. After 20 years of mechanicing, I've lost the passion for working on my own car. It may be different if I had access to a hoist, but it is what it is.
