Went to Ryogoku yesterday to watch the last tournament in Tokyo for the year and what a ripper it was.
Asa Shoryu lost and when the Yokozuna went down everyone started pegging the cushions they were sitting on at the ring - a tradition whenever the underdog beats the Yokozuna.
Had some great seats and what was really awesome was how close you could get to the ring during the lesser graded bouts - so close Wrestlers were getting thrown out of the ring right in front of us.
If youve never been to a Sumo tournament, i highly recommend it - these blokes are massive larger than life hard core kunts, with calves the size of my thigh...
People all talk about top secret this and Nismo that and cheap parts etc etc, but this was something you wont forget.
The tournaments are held in Tokyo at the Ryogoku station, 5 minutes from Akihabara and tickets can be bought at Lawson convenience stores or even from the official website http://www.sumo.or.jp/eng/
Events are held in Tokyo during March, May and September but are also held in Osaka and f*kuoka among other places throughout the year.
Tickets can range from 5000 yen all the way up to 50,000 yen for ringside.
This was the view from the rafters on the second tier
One of the walls outside the entrance:
Paintings coming to life. You feel so small next to these boys - they are massive.
The food that Sumo live off - Chanko...not to be confused with Chinko
The big kahuna trophy:
Other random trophies;
Pass out stamp only visible under black light:
https://www.sau.com.au/forums/topic/237127-farkin-sumo-mang/
Yeah went to the one in f*kuoka when I was studying there in 99...
shit eh, thats almost 10 years ago.
they're some big ass mother truckers...
its so funny seeing them riding around on their chari's (pushbikes) before the event!
yep, went to a huge tournament at ryogoku a few years back. it was one of the first things I wanted to do in japan.
I got "lost" though and "accidentaly" ended up in the go-man yen floor seats, ringside. :thumbsup: now that was awesome. :)
Outside the ring where the sumo were walking around lots of people were asking for photos with the sumo. some girls would get photos taken sitting on their laps. so I did it too and have a funny pic of me on a giant sumo's lap. I then asked if he would sit on my lap for a photo. lol. he didn't know if I was serious or joking but eitherway he wasn't game to crush me!
there was a few hairbacked gaijin doing pretty well too. but it just doesn't look right... ugh.gif
I still have some cool little figurines and stuff that I bought there.
ps. how many times a day do you type 'mang'? trust me when I say it's not as cool or funny as you think. and with huge overuse becomes quite annoying... srsly mang.
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
