  • Replies 310
Posted Images
on the plus side we get the extra dodge 1 aswell, which can come in handy for bumming around the home n working on the car n such :banana:
its not that much extra n on the plus side i dont think he made cash off us which makes me happy :P
https://www.sau.com.au/forums/topic/237131-hoodies/page/2/#findComment-4149179
its not that much extra n on the plus side i dont think he made cash off us which makes me happy :banana:
you would be surprised at how much those hoodies actually cost that's why its easier for him to just replace the stuffed up one and walk away from the whole situation and for him there is 2 positives out of this situation
1) we respect him as a businessman and probably wouldn't talk any further about his business (remember he doesn't do the printing)
2) he still makes a small amount off us just the profit margin is significantly reduced and i assume the printers would have to forfeit some of there profit too for making errors also
https://www.sau.com.au/forums/topic/237131-hoodies/page/2/#findComment-4149287
is it gonna be a print or embroidery?
dont be put off by the dodgey printing we've seen recently. a good print looks much better than embroidery imo. more detail. smooth finish. not lumpy, and doesnt distort the flow of the fabric.
https://www.sau.com.au/forums/topic/237131-hoodies/page/2/#findComment-4149444
Considering the situation, this is a very positive outcome. Well done to all involved. I look forward to getting both hoodies and the new one having a much improved finished design.
https://www.sau.com.au/forums/topic/237131-hoodies/page/2/#findComment-4150783
pretty good outcome i guesss.
two hoodies for $56 is pretty good for me.
specially since i earn less than that in a week being a full time year12 student yewwww. schools almost finished :)
will keep an eye on this for Madaz's quotes on new printing on new hoodies....
just a question...our new hoodie, do we get it the same colour as the first one we ordered?
https://www.sau.com.au/forums/topic/237131-hoodies/page/2/#findComment-4151101
can we get the 1st crappy hoodie sent out and then pay the extra 20-30 bucks when the time comes??
+1 for that question
Or do we have to wait for the new embroidery on the freebie blanks?
Oh yeah and thanks Adrian + Damo & anyone else involved for sorting out the mess!
Can whoever sorts out the new hoodies send a PM when the time comes because its hard for me to keep finding the threads on these things
https://www.sau.com.au/forums/topic/237131-hoodies/page/2/#findComment-4151183
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
