I have a r33 gts-t but with a rb26/30 engine in it, she has full forged internals - Arias pistons, Arias Rods, Full Tomei Gasket kit, upgraded cams...lets just say she is a weapon but he thing is its got standard turbos on it, im wondering if anyone out there could tell me whether to go back to a single turbo formation or keep the twin setup, also what type of turbos to use...im looking for big hp out of this engine as its built for it...
thanks every1 :)
https://www.sau.com.au/forums/topic/237148-rb2630/
Been looking at this lately aswell, as im leaning towards a home built RB26/30 instead of a straight Rb26
Lost of guys in the UK have done alot of research and testing on turbos for 3.0l RBs (one dude has tried like 5 different turbo setups...cash to burn) and there is loads of info on both the SAU RB30 dyno sticky and on the UK GTR forum.
But from what ive gathered in my research lately, ill give you sorta both ends of the power spectrums for both setups...
Most of the local boys seem to like using singles, with a GT30R as a minimum (350+rwkw) and serious cars use hardware like GT42Rs and T51Rs (600+rwkw).
But twins could still be an option. Garrett -5s are probably the minimum and i think would spool nice and quickly (350+rwkw) and on the other end the scale a highmount pair of Garrett GT3071s would make for a wild ride (600+rwkw).
You need to set some firm goals, both for power and responsiveness. What will the car be used for etc. And then use all the resources to work out what the best setup will be for you.
Hope that gets you started
https://www.sau.com.au/forums/topic/237148-rb2630/#findComment-4149100
A few people on here run GT3076R turbos in the .82 AR rears they are making good boost around 3000rpm and top out at 300-320kw, then there is the GT3582R, in .82 AR rear this turbo is capable of ~350-370kw and is on good boost levels around 3500rpm and with the 1.06 AR rear is good for a bit over 400kw with good boost levels around the 4000rpm mark. (by good boost levels i mean 1 bar or more)
i personally haven't looked into the twin setups much so cant really comment on them but the Veilside R32 drag car runs twin GT3582R's so if 1400hp is your goal that's a possibility :banana:
Edited by TiTAN
https://www.sau.com.au/forums/topic/237148-rb2630/#findComment-4149157
if your sticking with the stock manifolds get twin
else single high mount
as said above set some power/response/cars purpose goals
twin you need 2 of everything so it will cost more, unless you get soemthing like a GT-RS twin setup on stock manifolds
then you can utilise most of the existing hardware
high mount single ftw.....
https://www.sau.com.au/forums/topic/237148-rb2630/#findComment-4149256
Turbonetics GTK series gets my vote... either the 650 / 800. Just came out from a build with one of these and we are most impressed with the results. Compared to the Garrett items; cheaper, better build quality, and better performance IMO.
https://www.sau.com.au/forums/topic/237148-rb2630/#findComment-4149481
GT35R
T04Z
T51R
Twin GT-RS's
Twin 2540's
Twin -5's
Twin -10's
Since the day i drove my 3L ive wanted to have a go of a built 2630 with something like r34 n1's or 2530's just to see how much fun that can be in the hills
https://www.sau.com.au/forums/topic/237148-rb2630/#findComment-4159895
I don't think it's going to be a very fair comment from me as I do run an auto transmission with a high-stall convertor. Car is still at the tuners (awaiting new flex plate) so all I can go off is the initial graphs.
14 psi is reached at 4,200rpm...
I'll post up more info next week after the tuning is finished, as I believe this result can be improved by tweaking the E-01, so far only the F-CON has been tuned and not the EBC.
https://www.sau.com.au/forums/topic/237148-rb2630/#findComment-4169086
GT35R
T04Z
T51R
Twin GT-RS's
Twin 2540's
Twin -5's
Twin -10's
A mate has these on his 30, makes 540whp @ 1.3bar!
I've got a GT35R w/ .82 housing to go on my 30 :cool:
https://www.sau.com.au/forums/topic/237148-rb2630/#findComment-4169770
hurry up and get it on there already bubba :)
Soon! plenum should be ready very shortly, spoke to the fabricator on Tuesday, all the prep work was done and he was about to start welding!
Got a graph for the 2540's?
What else is done to it - cams, headwork etc?
I bet its a fkn rocket
No graph handy, it's a 25t head (no porting or anything), 272 cams I think, greddy plenum, q45 t/b.. and it's in a 4wd platform.. yes, it's a fkn rocket :D
I have a clip of it's first night out.. pm me if you want to check it out ;)
https://www.sau.com.au/forums/topic/237148-rb2630/#findComment-4172400
Not sure what to do with my exhaust.. was thinking 3" dump off the turbo, then join the gate pipe in where the front pump turns horizontal and flare to 3.5".. or should I be going bigger straight off the turbo?
Edited by bubba
https://www.sau.com.au/forums/topic/237148-rb2630/#findComment-4172480
    • So, I started this repair and got as far as "fixing" the holes with some fibreglass. God all those years working on boats came back quickly. I decided I'd reach out to some rust guys just to see what they would say about it. I came across a guy about 40 mins away and went to see him. He said the windscreen needs to come out, that there might be some more bits around the windscreen and he'd quote them at the time. But his quote was $300 to remove and replace windscreen and $3k for the damage he can see. He said he could respray the roof for $1200 and the bonnet for another $800 (somebody has previously rattle canned it, its horrendous). This is $5300 + any small additional bits. It's a lot, I get that and the name of one of my fave youtube channels 'Not Economically Viable' comes to mind.  I'm not being financially rational, but I've taken him up on the quote. He's opening a new shop in November with more room, so we're waiting for that. I'll leave the currently missing headliner out until then. I'm looking forward to it being fixed and having the paint looking nice again (lots of clear coat issues on the roof too). / flame suit on.
    • Oh and some up-and-comings; New rear drivers wheel bearing. I'll do that this weekend while the diff is out. The car is already up and the d/c axles and missing exhaust will help with space. This is the last bearing for me to do and I've been dragging my feet on it. I also have some new EBC blue stuff pads for the car and some new brake fluid. I haven't ever flushed the fluid in this car and looking forward to it. I have 600 degree fluid to put in. Not exactly "race fluid" but better than the typical stuff I have been using.
    • A proper clutch/plate type mechanical diff with quite a lot of pre-load and high locking % is better for drifting. Much more consistent in its behaviour. A helical can be annoyingly vague and inconsistent in how it responds under the sorts of abuse found in drifting.
    • Some updates here. I pulled the entire interior out, minus some trim to respray the seats with Colourlock dye. It turned out really nice though I accidentally let the dog in the car after and she scratched up the front seat.  This is what it looked like before, the colour was just washing out everywhere but thankfully the leather was in good nic. Then after the respray   And after the bloody dog jumped in The headliner is out waiting to be retrimmed, but it will stay out now until Nov - see why below. I replaced the stereo/headunit with a period-styled Android headunit. I have no after pics, but I'll get some. This is because of the missing pixels. I tried to fix this twice with replacement ribbon cables but couldn't. Also the bluetooth interface I'd bought for this was crap. Then there's the rusty roof. Pics and info in this other thread. I have decided to get this repaired professionally, but I'll update that thread. This is why the headliner will stay out for now. I'll be getting the roof and bonnet resprayed at the same time the rust is fixed. I also had an interesting issue with my drivers door lock.  For a small period I was having issues getting any 12v power to the car - I mean *any*. It would have no dash lights, nothing. It happened while I was at the shops and I couldn't get in the car. So, we had 2 problems. The most pressing here is that I was locked out. I have only a single physical key hole on the car, the drivers door and no amount of turning would unlock the car. Surely it doesn't need power for this? The second issue is why am I losing all power periodically, The battery isn't dead, its almost like the battery isn't even there. Two issues that were surprisingly easy to fix. You fellow BMW over-engineering lovers will appreciate this. The lock in the door has 5 states; mechanical lock, electric lock, neutral, electric unlock, mechanical unlock achieved at -90 degrees, -45 degrees, 0 degrees, 45 degrees and 90 degrees. Although, the unlock is towards the front of the car, so opposite for LHD countries. Sticking the key in and turning 45 left or right is what is used 99% of the time. It activates the central locking etc. 90 degrees is for dead battery access and, obvs, only un/locks the one door. But because the mechanical lock is never used and is 27 years old, it seizes up. I was totally unable to turn the key far enough to get to the mechanical unlock (At the time of locking myself out, I didn't even know this was a thing). I eventually did it with some vicegrips and teflon spray.  I made a quick vid for other E39 peeps.   The battery issue is totally new to me also - It wasn't making sufficient contact between the post and the terminal. The terminal was bolted on tight, but the car wouldn't have power. After checking the battery with my multimeter I accidentally contacted the terminal and the battery post and the car got power. The battery was only a few years old and in good condition. I cleaned the post and the terminal with a wire brush, bolted it back on tight and never had the issue again. I'm still surprised that despite having solid contact it didn't work. Also, the car was getting Warragamba sized pools of water in the back when it rained. My initial concern was another rust problem. But when I went out on Weds while it was raining and while I had no headliner in I could see a steady stream of water coming through the roof mounted aerial. As this aerial is for the (now removed) car phone I pulled it out and whacked a blanking grommet in the hole. It seems fine now. I'm thinking I might get the hole permanently filled when the rust is fixed. Moving forward and things in progress; The tailgate needs some attention. I have taken all the trim off to clean it all and address some small rust spots. I have partially done all of this but I'll finish it up hopefully this weekend. As all the trim are now entirely devoid of trim clips I have bought a heap of strong velcro and I'm hoping it does a good enough job as any of this trim in good condition is super expensive and usually in Europe as we dont have many of the wagons here. Suspension and brakes!!! This is exciting. In the front; New control arms New sway bar links New lower Eibach springs (the only modification I'm planning on this car) M Sport shocks (these came with the car and will replace the longer shocks in the car) New top mounts Used 540i calipers (stock brakes suck!) New 540i disks and pads (22x296 mm for 528 and 30x334 mm for 540i) New front wheel bearings (thank all that is holy for bolt on bearings!) Annnnd in the back; New control arms New sway bar links Adjustable air suspension arms (fool the car into what the current height is so the self levelling suspension can match the new front ride height) New ball joints I'll also be doing a brake fluid flush while I'm in there. I'm planning on switching the car over to the 16's that came with it so I can clean up and respray the M Sport 17's. They've lost a lot of colour over the years and have some gutter rash. None of this will start until the E90 is back.
    • You mean you will regret it for drifting duties? I don't quite follow.
