thanks every1 so far with comments, ive been really interested in either the t51r bb Kai or SPL, or t88....single setup tho, but i wouldnt mind keeping the twin setup :), i want to make big hp so keep them coming guys.., i wouldnt mind looking at the twin setup that TiTan come up with "Veilside R32 drag car runs twin GT3582R's"
everything is costly so i might as well go best then cheap!!!
thanks guys
Edited by 74nky
https://www.sau.com.au/forums/topic/237148-rb2630/page/2/#findComment-4175719
rb26/30 forged rods
pistons, acl bearings, n1 oil/water pumps, arp bolts everywhere. gt4094r single,4"dump.
run 2.5bar boost max 1.5bar by 3600rpm.full boost 4200.
superb turbo for road/track, responsive yet makes the numbers.
https://www.sau.com.au/forums/topic/237148-rb2630/page/2/#findComment-4190710
rb26/30 forged rods
very impressive. do u have a dyno sheet u can post ?
https://www.sau.com.au/forums/topic/237148-rb2630/page/2/#findComment-4192188
his post from the dyno thread
did some dyno work yesterday.lol
p.s. figures are bhp @ the flywheel.
well some of you know the car by now, and as i have have fitted a new turbo it was time for a tweek on the map..
still got some misfire issues and could only run 1.9 bar boost, but heres, the graph.
spec is.
rb30 block fully prepped with spool rods and cp forged pistons
n1 oil/water pumps,
jun stage one cams 264/272 9.7mm lift
1000ccs injectors,
twin in-tank tomei pumps feeding both ends of the rail, 8mm return to tank fitted.
gt4094r turbo, 50mm turbosmart gate, 4" downpipe.
plus usual bits lol.
https://www.sau.com.au/forums/topic/237148-rb2630/page/2/#findComment-4192285
sory to hijack
just on this topic im looking for a turbo a bit bigger than a 3582R but dont want to loose too much response due to car being used for drift.
have a rb30/26, forged pistons, rods, cams, high mount mani, greddy plenum, 100cc injectors and all the usual bits and pieces.
should i just go the bigger rear housing (1.06) or what is the next size turbo up?
cheers
Mitch
https://www.sau.com.au/forums/topic/237148-rb2630/page/2/#findComment-4192483
rockabilly - whats with the big midrange dip? Your loosing massive mid-range poke from 4700-5800
The line should continue building, and not drop off and resurge
Oh, and if anyone needs a T88 (saw it mentioned earlier) i know of a kit for sale. PM me if interested
https://www.sau.com.au/forums/topic/237148-rb2630/page/2/#findComment-4194618
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
