Make: Nissan
Model: Skyline R33 GTS-T
Milage: 155,000
Transmission: 5 speed, RWD
Colour: Black
Complied? N/A
RWC supplied? Yes
Currently registered? Yes
Price: $13,000
Contact: Aaron 0416495282
Comments / Modifications:
Tuned to 232kW at the wheels by Creatd Motorsports.
HKS GT2835 turbocharger with AVO 0.73 A/R exhaust housing.
GTSLink engine management system (includes boost control, launch control, flat shift functions - comes with USB adaptor, tuning software and manuals).
Haltech boost control solenoid.
720cc high flowed injectors by Creatd Motorsports.
Bosch 044 fuel pump.
Front mount intercooler.
HKS super sequential blow off valve.
Apexi air filter, induction pipe by Creatd Motorsports.
SSW Eclipse 19x8" wheels (front tyres: Falken Azenis ST115 235/35/19,
rear tyres: Maxxis Victra MA-Z1 245/35/19).
Bilstein shock absorbers.
DBA slotted front brake rotors.
Trust style front bar.
GTR style rear wing, side skirts, rear pods.
Mirror headlights from 4 door model (crystal clear & clean - hasn't turned yellow or fogged).
HICAS lock bar.
Cusco front strut brace.
Nardi steering wheel & HKB boss kit, Nismo gear knob.
Tinted windows.
Alarm/immobiliser.
Sony Xplod black face headunit with Xplod speakers.
Soundstorm 2000W amplifier .
2x 12" Pioneer subwoofers in enclosure.
12 months registration & RWC included on purchase.
Receipt book kept for all work.
Regularly serviced by reputable workshops (RE Customs, Creatd Motorsports).
Recent wheel alignment and balance
Most of the performance modifications and tuning were carried recently (July).
Reason for sale is my wife and I are relocating to New Zealand.
Extremely tidy inside and out, nothing left to do.
Images:
Edited by aaron_25t
https://www.sau.com.au/forums/topic/237168-1993-nissan-skyline-r33-gts-t/
I obviously can't say there's nothing wrong with it at all :) But put it this way, I'm very happy with the car as it is (I've spent a fair bit fixing things that bothered me). Here's a few things that aren't quite right:
1. One of the custom brackets holding the air filter has snapped. I'll get this fixed on the weekend (this is a support bracket only - air filter is still on car).
2. The paint is really good as you can see from the pictures but there is the odd small scratch on the car if you look closely.
3. Electrics - everything works except the RHS drivers mirror doesn't fold in when you hit the button. I never bothered fixing it as I never use this - all other mirror functions work. Easy fix for <$100 I would say.
18psi on a conservative tune - not sure if you'd want to run higher than that, but I would say with a bit more fine tuning, some aftermarket coil packs and maybe decat or hi flow cat and you'd get pretty close.
Wow!! so cheap nothing wrong with it at all?What boost did it make that on... much room for more maybe 250kwaw?
Edited by aaron_25t
  • 1 month later...
The tuner mustnt know what he's doing. With that sized injectors, it's got enough to pust past 250rwkw.... maybe even 285rwkw. Slap a Haltech E11V2 or even just a PowerFC in there and do some rippin....
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
