  • Replies 94
the car isnt actually that bad.
if/when it gets defected all ill need is stock wheels, stock suspension, and stock exhaust. then just remove boost controller and that little shit.
guages etc are legal, so it wont be that much hard work.
lol mods are the least of ur worries going through inspection mate, its the roadworthy stuff ull get pinned on. it depends on the inspector and their impression of ur car, but as an example i have been failed for things like a small tear in my drivers seat, a patch of oil about 1" in diametre in my engine bay etc etc, ive been pretty lucky in the past though as i go completely over the car, tidy everything up, degrease the engine, spray the underside of the car, and since ive been through the process and know what they look at i pass 1st go most of the time. when my car came in from Japan i took it to a compliance place and on top of the actual compliance work they gave me 2 pages worth of shit to fix/replace myself before going through regency, and the car was in pretty good nick, so there's not heaps to do before i go through each time now days as most of it has been fixed to get through regency not long before but its still at least about 20hrs of work to get the car ready for regency each time.
I want what SHYGRL's rolling on, very nice looking rims. They fit a GTR?
Or i want some Volk Racing GT-C's in the gold. very noice :cool:
definitely tough rims, i have the same ones but in bronze. (17x9, +20 and +30) so they wont suit a GTR unless u fit 10mm spacers to the front.
these will also be for sale in the next couple of weeks.
To all those saying you must buy "jap rims" this is what wheelworx can supply :cool:
It's all about knowing what offset you need and ordering accordingly, NOT going to Knob Jane and asking for "rims that will fit your skyline" because then you will get whatever they have in 5x114.3 in absolute shit offset
so you mean, 34 gtr rims? lol.
hmm, i guess i do, haha.
weight can also be a factor when buying aus(china) rims over japs rims, but if your just cruising in your car and its not a track car that needs to save weight then it really doesnt matter
it does matter, just not as much. light wheels help ur suspension absorb bumps better and transfer less shock into the chassis, better ride comfort, handling (grip), accleration and braking. how much u notice it depends i guess.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
