  • Replies 94
the car isnt actually that bad.
if/when it gets defected all ill need is stock wheels, stock suspension, and stock exhaust. then just remove boost controller and that little shit.
guages etc are legal, so it wont be that much hard work.
lol mods are the least of ur worries going through inspection mate, its the roadworthy stuff ull get pinned on. it depends on the inspector and their impression of ur car, but as an example i have been failed for things like a small tear in my drivers seat, a patch of oil about 1" in diametre in my engine bay etc etc, ive been pretty lucky in the past though as i go completely over the car, tidy everything up, degrease the engine, spray the underside of the car, and since ive been through the process and know what they look at i pass 1st go most of the time. when my car came in from Japan i took it to a compliance place and on top of the actual compliance work they gave me 2 pages worth of shit to fix/replace myself before going through regency, and the car was in pretty good nick, so there's not heaps to do before i go through each time now days as most of it has been fixed to get through regency not long before but its still at least about 20hrs of work to get the car ready for regency each time.
I want what SHYGRL's rolling on, very nice looking rims. They fit a GTR?
Or i want some Volk Racing GT-C's in the gold. very noice :cool:
definitely tough rims, i have the same ones but in bronze. (17x9, +20 and +30) so they wont suit a GTR unless u fit 10mm spacers to the front.
these will also be for sale in the next couple of weeks.
To all those saying you must buy "jap rims" this is what wheelworx can supply :cool:
It's all about knowing what offset you need and ordering accordingly, NOT going to Knob Jane and asking for "rims that will fit your skyline" because then you will get whatever they have in 5x114.3 in absolute shit offset
so you mean, 34 gtr rims? lol.
hmm, i guess i do, haha.
weight can also be a factor when buying aus(china) rims over japs rims, but if your just cruising in your car and its not a track car that needs to save weight then it really doesnt matter
it does matter, just not as much. light wheels help ur suspension absorb bumps better and transfer less shock into the chassis, better ride comfort, handling (grip), accleration and braking. how much u notice it depends i guess.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
