hello have you ever licked the underside of an ice cube?
anyway, ive currently got an east bear/gtr front bar and bonnet on my car and im looking for a change.
i have no idea what other kits are available for the gtt's
so what are some nice front bars? something that will sit nicely with the factory nismo skirts/rear bar
ps. i dont want the new front bar to make the front end/car look anything like a gtr!
thank you
Edited by R-SPEC
https://www.sau.com.au/forums/topic/237319-front-endsbars-for-r34/
CWEST ?
Theres a knock off model based on the CWEST kit on Carmate.com.au
Havent had any experience with their kits, but the promotional pics on their site dont look too good, crappy quality and angles dont show you the good sides of the "CW" kit. Google it :(
MRXTCZ
Can someone post pics of :
Do Luck Kit
Top Secret
East Bear
C West
Kits please.
I would do it here, but due to stupid internet protocol at work they dont let me upload images or multimedia -.-
idiots i tells yah!
MRXTCZ
here is a pic of the do-luck front bar for a gtt
and here is a topsecret one, but fot a gtr, its basically the same anyway
and the cross factory kit, but used on a 32-34 conversion
Edited by RusH_
^ he'll never be done!!!!!!!!
he doesnt answer his phone, reply to sms's & emails & pms!!!!!!!!!!!!!
nothing can beat gtr front end :)
as for rear bar & side skirts, im still choosing which one to get. everything ive seen are ugly! if only vertex made a R34 kit lol
Edited by dori32
    • Welp, good to know. Will have to wait awhile until steady hands with drills and taps are available. In other news, these just arrived! I will weigh them for posterity.
    • 100% the factory sender is tapered, that is how it seals (well, that and teflon paste or tape)
    • Thanks folks - I've saved a few links and I'll have to think of potential cable/adapters/buying fittings. First step will be seeing if I can turn the curren abortion of a port into something usable, then get all BSPT'y on it. I did attempt to look at the OEM sender male end to see if it IS tapered because as mentioned you should be able to tell by looking at it... well, I don't know if I can. If I had to guess it looks like *maybe* 0.25 of a mm skinnier at the bottom of the thread compared to where the thread starts. So if it is tapered it's pretty slight - Or all the examples of BSPT vs BSPP are exaggerated for effect in their taper size.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
