1990 r32 GTR
i have put my life into this thing $50000+ $$$$ it has been fun but time to part i have to put more $$ into my business so keep it running
i really really dont want to sell it but i guess life sux :thumbsup:
now please i have put the price what i think is far with the time money has been spent on this thing if use dont like it please dont say anything
sits on 17" wheels with 95%tread white ssr rims
has full tein suspension all round
full 3 1/2 exhaust system high flow cat big cannon
has 3 blitz gauges oil pressure boost and water temp
HKS evc controller
power fc
ENGINE / INDUCTION
CP PISTONS AND RINGS 86.5MM
EAGLE RODS
TOMIE FULL METAL GASGET SET
TOMIE OIL PUMP
ATI BALANCER
ACL RACE SERIES MAIN AND BIG END BEARINGS
HKS VALVE SPRINGS
ARP HEAD STUD KIT
ARP MAIN STUD KIT
NISSAN GASGET SET
JUN CRANK COLLAR
TRUST SUMP EXTENSION
HKS FUEL RAIL
SARD FUEL REG
HKS 115MM THINK INTERCOOLER
HKS CAM GEARS
POWER FC ECU
GARRET GT35R TURBO
TOMEI PONS CAMS \
TWIN PLATE 800HP CLUTCH
TWIN Z32 AIR FLOW METERS AND PLUSG
sard 700cc injectors
car made a easy 370kw on 19psi with super safe tune
more boost and strong tune make 420kw easy on this turbo
engine will handle 800hp easy with bigger turbo but i wanted a quick street car not a lag monster
please if you have nothing nice to say dont say it please
work was done by GODZILLA in brisbane
PRICE $48000
https://www.sau.com.au/forums/topic/237586-r32-gtr/
Rode in a car with a very similar setup and KW. IT CHANGES YOUR FUC&!N% WORLD! These cars feel as if the world is going to end and yet feel incredibly safe with this sort of grunt. Goodluck, spectacular R32, and a free bump
https://www.sau.com.au/forums/topic/237586-r32-gtr/#findComment-4202769
    • Well, yes, every CU on the bus is available via the Consult port, but whether the scanner you are using is capable of talking to the TCU, the ABS/TCS modules, etc etc, is what is at question here. Many of them are only for engine codes. So, if you have one of those, you won't know if the ABS is having a bitch.
    • That's now. R chassis Skylines come from a time when the tolerance in the ADRs was a bit more....slack. My car, on 235/35-17, which is damn near the exact same size as the original 205/55-16, is pretty much bang on correct indicated speed across the whole legal range. That's demonstrated with constant speed run over 5km, and GPS speed. It's just the luck of the draw. My particular speedo head has to be the thing that is "calibrated" that way, because everything else (the diff ratio, the gearbox and the speedo drive**) are all same same as most other Skylines. **OK, so the speedo drive is a Navara unit to drive the R32's cable, not the electronic unit than an R33/4 would normally have with teh same gear on it. Otherwise, I applaud your OCD tendencies, and I would do the same if I needed to.
    • Not too sure, I believe the Nissan consult port does everything? Also just filled up the reservoir to full and the light is still on. The float seems to move up and down fine.
    • The speedo's can be very conservative, when my Mazda NC MX5 speedo is showing 118kph, the GPS, and a calibrated radar.... cop mate.....hits me at around 110kph +/- 1 or 2 kph, and that is on a 215/45 17, stock tyres size is 205/45 17 as well, so weirdly conservative with stock tyre size When my Commodore speedo red 116kph GPS had me at 110kph on 255/40 17, so again conservative Google says manufacturers need to set the speedo from 4 to 10% slower than actual road speed.....for safety.....and compliance  After doing some offset and clearance measurements to see what can fit the NC on 17x8 +40, without guard rolling or rubbing anything at my current ride height, I've decided that when my tyres are toast, I'm going to fit 225/45 17 and see where that gets me IRT actual speed of my speedo and GPS/radar From the online calculator I should be still be doing around 5kph under an actual 110kph when the speedo is showing 110kph My ADHD requires that when I'm doing 110kph on the speedo, that the actual road speed is actually really close to that, and not alot slower And going from 205 to 225 still keeps the car within the %/mm allowable in the NSW vehicle rules and regulations, which is nice, as long as I'm looking at the latest version that is.....LOL https://www.nsw.gov.au/sites/default/files/2021-02/RMS-13.464-Light-vehicle-modifications-Vehicle-Standards-Information-No-6-November-2013.pdf
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
