Go to one of the tune shops that can tell the difference between a GTR and a GTS-T.
the usual suspects would be
C Red
SST
Speedworks
Some people may have a beef with some of the shops but they can all check a line over and tell you what's wrong.
Also get a cylinder leakage test done , is a good indication of engine .
Cheers
Ken
https://www.sau.com.au/forums/topic/23766-skylinerac-check/#findComment-508702
it would be unlikely that they'll come out and have a look at the car.
when i first purchased my Line i had it looked over by the guys at Cypher Industries. cost me 70 bucks but the more or less stripped the whole car and even checked for panel damage on the inside bla bla bla
took close to 2 hours and included a lengthy report. all in all i reckon it was money well spent
https://www.sau.com.au/forums/topic/23766-skylinerac-check/#findComment-508731
Yeah i found a nice skyline, just wanna get it checked, thanks for that G0DF4Th3R and gtrKen, i didn't know Speedworks was in Ossie park, conveniently the seller and I both work in ossie park :P
Nah,
I've sorta canned that idea, purely cause it was going to take to long, too much hassle, and considering i could get a turbo car with selling mine and using the money that was going to be used on the engine.
I change my mind too much!!!
Kris
https://www.sau.com.au/forums/topic/23766-skylinerac-check/#findComment-508769
How is this test done? Is it the oil around the outside of the engine? Can you tell the engine is leaking just by lookin at it , apart from "oh theres oil around the engine" cause sellers can wipe it clean just before someone buys it. (Sorry, another one of my dumb questions!)
Thanx y'all!
https://www.sau.com.au/forums/topic/23766-skylinerac-check/#findComment-509065
Thanx y'all!
Remove spark plugs and run compressed air thru a special gauge which tells how much blowby, valve, head gasket etc problems you may have.
Cheers
Ken
https://www.sau.com.au/forums/topic/23766-skylinerac-check/#findComment-509388
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
