heyyy im new to this forum i was just wondering if someone could help me out i own a r32 skyline gtst ive got a problem where my car cuts out at about 5500rpm it boosts no problem up until that point i got told it could be my coils or injectors??
i cant afford to change both things as a lack of funds any tips of wat i can do i was looking at forum about clear nail polish on the coils or tape???thanks
https://www.sau.com.au/forums/topic/237782-r32-gts-t/
  • 4 months later...
Well what does it excatly do? loss of power? Misfire? Surge?
All R32 have problems with the standard coils at this age.
My car and my best mates had the same problem and all the things you can do to stop it only give you a little more time until you buy splitfire coilpacks around $600 now i think.
Things you can do:
Make sure the boost isnt wound up too high
Reduce the spark plug gap to no smaller than 0.7mm
Check condition of Air Flow Meter, i had dramas till i found a great guide on these fourms to fix AFM's
Clean coil packs and rubbers externaly
Edited by Curlz
https://www.sau.com.au/forums/topic/237782-r32-gts-t/#findComment-4443990
Hi
I have had the same issues with my 32 as well, before i bought a set of new splitfired, i used that 5 min opoxi glue over ever bit of the coil she lasted for a few month but as time went on i could start to feel it breaking down at higher RPM so enough was enough new coils had to come :P
cheers
paulie
https://www.sau.com.au/forums/topic/237782-r32-gts-t/#findComment-4462448
  • 2 months later...
Things you can do:
hey mate i had this problem with my r33 rb25det. found out my feul pump was f@?$ed even though it still ran. put it on the dyno dude it will tell ya strait away spend $100 on dyno tune and that will tell ya everything mate. let me know how ya go eh. :cheers:
https://www.sau.com.au/forums/topic/237782-r32-gts-t/#findComment-4616696
  • 4 weeks later...
  • 4 weeks later...
hey man does it make a popping sound.
if so mine had the same and it was fuel pump. upgraded to walbro 500hp and works a treat.
https://www.sau.com.au/forums/topic/237782-r32-gts-t/#findComment-4726881
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
