Can anyone recommend a reasonably priced polisher such as the Mothers Palm Polisher (I don't need to do correctional work) and where to get it? (or do you have one I can borrow)
I am also after stores that sell Dodo or Zaino polishes. I have been using the Maguires range, and they are fine but would like to try some of the better stuff, in particular the Zaino Z2pro or Dodo light fantastic to get the silver to POP.
Edited by 4door_Sleeper
https://www.sau.com.au/forums/topic/237896-polishers/
im using this stuff called polyglaze (sp?) diamond cut polish and that seems to work very well. gave the paint a very smooth look.
i cant remember were i got it from though? i havent seen it in many places either. ill ask the missus cause i think she bought it some time ago.
https://www.sau.com.au/forums/topic/237896-polishers/#findComment-4160574
give brian burns from car groomers pooraka a call,c if he help. he has a one of a kind swirl remover polisher,u cant buy from anyone,used to work with him,it works frigin awesome,worth the ask
https://www.sau.com.au/forums/topic/237896-polishers/#findComment-4160741
i use 3M glaze polish, with an 'eggpad' buff (which i go over by machine) takes care of swirls
then handpolish with meguiars 'next gen' polish using one of those round applicators, then polish off with a microfiber towel. this gives a nice shine
comes up great :closedeyes:
only thing is i dont have a very good buff, just a cheap ryobi that has 2 polishing speeds, too slow and too fast lol
https://www.sau.com.au/forums/topic/237896-polishers/#findComment-4161118
Sincew the car was resprayed I have taken good care of the paint and have very few (if any) swirl marks.
I usually:
Wash the car
Clay it with the Meguiars Clay bar and Quick Detailer for lube
Wash the car again
apply Meguiars NXT Gen Tech Wax
Wash the car again
Apply 2 coats of Meguiars Hi Tech Yellow Wax.
I have read that I can get a better finish if I use the Z2-pro after the second wash and before the wax. I am after clarity and shine here rather than correcting defects (as there are very few).
https://www.sau.com.au/forums/topic/237896-polishers/#findComment-4161126
yeah i forgot to mention i wash the car first then go over the whole car with a 3M claybar.
i doubt there is much point in waxing the car so many times, each time you apply another coat you are removing the previous coat
https://www.sau.com.au/forums/topic/237896-polishers/#findComment-4161268
Its called "Layering", and as said, the layers need to cure (usually 24 hrs) before reapplying.
If you check out some of the professional detailing/polishing forums they have lots more information on it.
I believe it enhances the final finish, but its a diminishing return (the first layer makes the most difference, subsequent layers only improve the finish little bit more).
https://www.sau.com.au/forums/topic/237896-polishers/#findComment-4161515
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
    • Wrinkle black will be a thing for both
