Can anyone recommend a reasonably priced polisher such as the Mothers Palm Polisher (I don't need to do correctional work) and where to get it? (or do you have one I can borrow)
I am also after stores that sell Dodo or Zaino polishes. I have been using the Maguires range, and they are fine but would like to try some of the better stuff, in particular the Zaino Z2pro or Dodo light fantastic to get the silver to POP.
Edited by 4door_Sleeper
https://www.sau.com.au/forums/topic/237896-polishers/
im using this stuff called polyglaze (sp?) diamond cut polish and that seems to work very well. gave the paint a very smooth look.
i cant remember were i got it from though? i havent seen it in many places either. ill ask the missus cause i think she bought it some time ago.
https://www.sau.com.au/forums/topic/237896-polishers/#findComment-4160574
give brian burns from car groomers pooraka a call,c if he help. he has a one of a kind swirl remover polisher,u cant buy from anyone,used to work with him,it works frigin awesome,worth the ask
https://www.sau.com.au/forums/topic/237896-polishers/#findComment-4160741
i use 3M glaze polish, with an 'eggpad' buff (which i go over by machine) takes care of swirls
then handpolish with meguiars 'next gen' polish using one of those round applicators, then polish off with a microfiber towel. this gives a nice shine
comes up great :closedeyes:
only thing is i dont have a very good buff, just a cheap ryobi that has 2 polishing speeds, too slow and too fast lol
https://www.sau.com.au/forums/topic/237896-polishers/#findComment-4161118
Sincew the car was resprayed I have taken good care of the paint and have very few (if any) swirl marks.
I usually:
Wash the car
Clay it with the Meguiars Clay bar and Quick Detailer for lube
Wash the car again
apply Meguiars NXT Gen Tech Wax
Wash the car again
Apply 2 coats of Meguiars Hi Tech Yellow Wax.
I have read that I can get a better finish if I use the Z2-pro after the second wash and before the wax. I am after clarity and shine here rather than correcting defects (as there are very few).
https://www.sau.com.au/forums/topic/237896-polishers/#findComment-4161126
yeah i forgot to mention i wash the car first then go over the whole car with a 3M claybar.
i doubt there is much point in waxing the car so many times, each time you apply another coat you are removing the previous coat
https://www.sau.com.au/forums/topic/237896-polishers/#findComment-4161268
Its called "Layering", and as said, the layers need to cure (usually 24 hrs) before reapplying.
If you check out some of the professional detailing/polishing forums they have lots more information on it.
I believe it enhances the final finish, but its a diminishing return (the first layer makes the most difference, subsequent layers only improve the finish little bit more).
https://www.sau.com.au/forums/topic/237896-polishers/#findComment-4161515
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
