only problem is they do get caught and get locked up but get out again.... the system is just too soft, obviously these deros have no life and prob dont mind getting locked up cos they'll get a free nice feed for a few days...
all the best getting it fixed mate, that really is disgraceful :D
thing is, they need to be shot.
like i wanna be realistic here, they are just scum, the only thing that makes them a threat is their lack of respect for anything, anyone and themselves, they dont care what happens to them, and that is dangerous.
f**k rehabilitation, just dispose of them and be done with it. its a hard view, but honestly some times civilisation needs to grow some balls and stand the f**k up for itself. the only reason they are able to keep doing what they are doing is the law as ironic as it is, it doesnt do shit when they are caught, and if anyone was to do the world a favour and killed one of these things they would end up behind bars.
and for people thinking, oh there life isnt worth some vandilism here and there, its not just that, they hunt in gangs and pick on people without numbers, they roll them and sometimes just beat them for the hell of it, its only a matter of time before they kill someone if they havnt already. ive had quite a few groups of aborignals try and start with me, luckily theres usually cops near by or im not far away from my mates.
  • Replies 75
+1 the world would be a much better place, not so over-populated, less deadbeats, tax money doesn't get wasted giving them a free bed and meals..... and so forth.
yeh not a great feeling to know your tax dollars are going to support a bunch of drop kicks spend their days going around breaking shit, getting drunk, chroming and starting fights. they dont just drain on the society, they f**k it up as well. they bring nothing good to the world, the most useful thing they could do is be buried 6ft under and provide nutrients to the plants above.
maaaan u must b hating life... sux baaadly. sorry 2 hear tho..
i play indoor at st clair (woodville) went to my car 2 go hm n i saw about 6 abboz breakn in2 my mates 32. n i wnt up 2 them, n they went 2 hit me so i legged it 2 my mates n then me chased them away.
the damage tht they did was rediculous........ they came sooo close 2 taking the car. luki we stopped them coz my mate bought it frm vic lyk a week b4 n already had 2 put up wid tha bulsh** u kno.
id say it was the same ppl tho considering its in tha same area...
we got the rego of tha car they were in but that was also stolen!!! OF COURSE!!
ironic coz my mates aboriginal aswel (not lyk the usual 1s on west tce tho) :/
dont they teach english in schools anymore ?
hahaha sorry about that...
still in text msg mode.
text mode.........more like Mongolian to me, lol................I get a headache trying to make sense of posts like that
yeah I think we should ban l33t speak, all caps, and txt on these forums. I too got a headache from trying to decipher that. I deleted your triple posts too.
Oh, and I have decided to edit the topic title, to make it a bit more family friendly.
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
