Well I guess I have learnt a big lesson today about guardrails, and learnt the hard way.
I hit one in my R33 and its mashed up the passenger side front guard, the bumper (repairable), bonnet and headlight.
The inside of the engine bay behind the passenger side headlight looks like a bit of a mess and it compressed in and squashed my pod filter.
There is probably suspension and structural damage although its hard to see. The car however was drivable and i had to drive it 1.5hrs to get home on the freeway and it didnt rattle or wiggle or steer funny.
I called the police and asked what I had to do and they said since:
- noone else was involved'
- the car did not need towing
- i wasnt under the influence
- i just hit the guard rail
i dont have to file a report.
Has anyone else had this kind of thing happen?
https://www.sau.com.au/forums/topic/23807-skyline-vs-guardrail/
Well I rang the Police Assistance Line because I figured if I was going to make an insurance claim I may need a police report.
Besides I didnt need to give them my name or anything to ask for advice on this.
It was thinking I might also be liable for some damages to the guard rail or something, but aparently not.
Dont think i will make an insurance claim tho, seems to be fairly managable damage.
befor claiming on insurance get sum quotes, if you claim you will need to pay the exess and the the premium will go up and you will always have to say you have made a claim when getting other insurance, in the long run you are better to just fix it your self i wouldnt think it would be 2K max for the complete fix.
Thanks for the advice dude. I will be taking it to a few panel shops around where I live tommorrow for a few quotes.
Probably not worth making an insurance claim like you said. In the long run I would end up paying 2 or 3 times the repair costs.
Originally posted by 2fardown
You made the right decision calling the police and asking for advice.  Better then getting denied when you claim on insurance.
Thanks. Yeah i also figured it would be better to be upfront to the police now and face the consequences if any than worrying needlessly about if I had broken any laws and facing some criminal charge or something.
you will be looking more like 4k to fix that damage. If its bent up around your pod, that involves beating it back into place and most likely getting it on a chassis machine. also new front bar, bonnet, light, guard + paint is going to cost. Also any suspension bits too.
best bet is too get some quotes from reliable panel beaters and then decide. Dont just go for a cheap one too as it may cost u in the end!
Thanks yeah 4k is close. I have priced up parts and stuff and im looking at about 1500 for body parts 1000 for panel beating. Then comes painting and anything else i havent discovered yet.
If you could still drive it home without it taking off in different directions then I doubt your chassis is bent.
thanks yeah, I pretty much had to drive it home. I drove it for about 1.5hrs at up to 100km/hr on the freeway. It seemed fine and didnt wobble or travel off the road by itself.
i guess i will find out tonight after the panel beater has had it all day.
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
