hi .
http://www.nengun.com/orc/409-series-singl...te-clutch-400ps
what is the difference between ? :merli::laugh::laugh:
1-ORC-409-01N Nissan R32,R33,R34 GTS RB25DET, RB20DET (Standard Type, Dampier Not Attached )
2-ORC-409B-01N Nissan R32,R33,R34 GTS RB25DET, RB20DET (Dampier Not Attached, High Disk Type)
3-ORC-409D-01N Nissan R32,R33,R34 GTS RB25DET, RB20DET (Standard Type Dampier Attached)
4-ORC-409DB-01N Nissan R32,R33,R34 GTS RB25DET, RB20DET (Dampier Attached High Disk Type)
5-ORC-409DS-01N Nissan R32,R33,R34 GTS RB25DET, RB20DET (Dampier Attached Silent Type)
6-ORC-409DSB-01N Nissan R32,R33,R34 GTS RB25DET, RB20DET (Dampier Attached Silent + High Disk Type)
7-ORC-409S-01N Nissan R32,R33,R34 GTS RB25DET, RB20DET (Damper Not Attached, Silent Type)
8-ORC-409SB-01N Nissan R32,R33,R34 GTS RB25DET, RB20DET (Dampier Not Attached, Silent + High Disk Type)
what I want who is better and what difference ?? :blink:
pls : anyone help me !!
https://www.sau.com.au/forums/topic/238083-orc-clutc-kit/
seems to be 3 configurations between having a dampier( dampener?) , silent type, and high disk, i would say the high disk type would probably be the strongest, have you considered an exedy clutch from slide, they havent got the lightened fly wheel but are half the price
https://www.sau.com.au/forums/topic/238083-orc-clutc-kit/#findComment-4163108
what are you mean any number 1..2..3..4....8 ?
please: can you mean any type from EXEDY ? PLS: I want to write to me direct from the site you mean any type EXEDY STRONGER AND HULF PRICE !!! :P:)
PLS: let me know becouse I can choice and purchas !!
thank you very much my dear ,,, thank you man ..
Edited by bkc
https://www.sau.com.au/forums/topic/238083-orc-clutc-kit/#findComment-4163407
i sell both exedy and ORC and the orc is a way better clutch, if you compare apples to apples the exedy clutches are dearer by a fair margin.
http://www.mcse1000.fsnet.co.uk/Ogura2.jpg
i use a ORC-709d behind our 26 and have tried just about everything including a carbon twin.
https://www.sau.com.au/forums/topic/238083-orc-clutc-kit/#findComment-4163457
thank you very much my dear.
but, I want single clutch kit enouph for me ..! :P
Thanks all .
https://www.sau.com.au/forums/topic/238083-orc-clutc-kit/#findComment-4163540
yeh i didnt realise it was for a gtr when i wrote that
Nissan Skyline R32-R33 GTST & R32GTR
Heavy Duty 5 Puk Button clutch kit, $439
Heavy Duty Cushion Button clutch kit, $445
ORC Single Plate clutch kit ORC 409D-01N (400ps) (Includes flywheel), $1229
Nissan Skyline R33-R34 GTR & R34 GTT (Late R32 GTR)
Heavy Duty 5 Puk Button clutch kit, $739
its funny that the exedy 5 puk is 300 dollars dearer for a gtr... but the orc uses the same part number for gtst n gtr =P
here the page for slides clutches..
http://www.skylinesaustralia.com/forums/Ch...l&hl=clutch
https://www.sau.com.au/forums/topic/238083-orc-clutc-kit/#findComment-4163977
Thank you very much my dear .
but what advice to me ? EXEDY !! any taype ? from EXEDY ? I want single clutch kit (includes flywheel) 400 :D ps !!
pls :write site and taype page ... clutch kit ) better price !! :D
Thank you advance .
https://www.sau.com.au/forums/topic/238083-orc-clutc-kit/#findComment-4164350
pls: advice to me , who is better ,stronger , and LIGHT WEIGHT ,, BETTER price up to 400ps ??!! full kit with flywheel ?
you have other site ? better price for what I need ! pls: let me know ..
pls you can see the site !!
http://www.rhdjapan.com/home/search/search...kit&go=Go%21
https://www.sau.com.au/forums/topic/238083-orc-clutc-kit/#findComment-4164390
please :: help to me any type I can choice single clutch kit (EXEDY) includes flywheel) 400 PS !! LIGHT WEIGHT !! (FULL KIT) LOWER OR GOOD PRICE ?
I want know purchase from any sit good price ??!!
thank you advance ...
https://www.sau.com.au/forums/topic/238083-orc-clutc-kit/#findComment-4165391
pleeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeees help to me :D:down::mad: :mad: urgent urgent ooooofff waaaw !!!
https://www.sau.com.au/forums/topic/238083-orc-clutc-kit/#findComment-4165834
https://www.sau.com.au/forums/topic/238083-orc-clutc-kit/#findComment-4165837
    • Biggest thing is you're okay!   It sounds like between the accident, and the drive home, it was a pretty torturous trip again! On the bright side, you took the opportunity to enjoy the event more from the perspective of a spectator, than as an entrant!   Sad to see so much damage to the car. It really has taken a HUGE hit in the front end. If/when you choose to repair, hopefully the rails are straight (At least from shock tower backwards). Hopefully the extra cage coming through there has save most of the chassis rails, and HOPEFULLY saved the motor too. Best of luck when you eventually get motivated to start pulling it down to check it all out
    • Sounds more like what Brad said, that it's mainly transfer. What pad bed in procedure did you use, and did you replace/machine the rotors, or just swap pads?
    • The stutter is almost entirely in the pedal. I don't feel the brakes release and reapply as you would with ABS engaging but the pedal feels that way, without the brakes releasing. It only lasts for less than a second and the pedal is fine again. It's hard to explain, sorry.  I'll get under this weekend and just double check everything is tight. Fluid is at max where I left it.
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
