In this shot, it looks kinda like you might be able to fit another keg in the fridge. Have you measured it up?
Then you could have two different flavoured brews going, or have two of the same and never run the risk of running out.
  • Replies 40
Posted Images
Then you need another gas bottle and more lines..........meh.
Just thought it must be a low temp yeast like pilsner cos a month is a long time. I'm into my pils atm. Brewed a Stella and never went back.
Nah it's cause its 6.1% alcomohol. 4kg of sugar!
anywho. Im picking up a 2 week brew this saturday (if I am alive). I think its an ale.
Pete - these are the puppies I scored today, 16 have liquid contents the other 32 - spider contents.
The stout was obvious, I couldn't pick the difference between the cider and the ginger beer. I have cleaned a couple up and thrown them in the fridge.......
When are you available to assist with the research?
  • 1 month later...
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
