As most of you a prob aware by now, my 33 started a boost leak on kellies last cruise,
was thought to be the gasket between the inlet manifold and the turbo,
after much f**king around, snapping studs, and having to go as far as taking the whole turbo out,
i put it all back together over last night and this afternoon,
and the verdict ITS STILL f**kING DOING IT!
and to add fuel to the fire, its blowing a little clack smoke (never used to)
and runs/idles like shit!
im so over this f**king thing,
but, any ideas on whats going on?
if not, ill be taking it to a workshop and let them rape me in the ass,
im not pulling the kent apart again
https://www.sau.com.au/forums/topic/238245-what-the-fk-is-wrong/
  • Replies 120
Posted Images
everthing is tight, most of the joiners are brand new....
im tempted just to drive it to morpowa and tell em i dont want it back till its sorted...
i just dont wanna miss out on kadina on saturday....
cars....why do we bother?
Im sure you probably have but, have you made sure all your silicon and rubber hoses for the piping are all in good condition when i first bought my car it had a boost leak because a 90 degree rubber elbow for the IC piping had a crack in it.
black smoke means you have a fuel problem, like too much of it. or a vacuum leak stuffing up the air fuel ratio.
could be a hose loose , a fuel regulator stuffed(pretty common on the older skylines) or even a jammed fuel injector, leaking fuel into cyl.
are u sure you didnt forget to plug in a vacuum line or maybe crimped it somehow?
does it run at higher rpm out of gear or stumble bad? under load does it run good or stumble bad?
kinda hard to troubleshoot without see it in person but hope this helps the hunt
pull your afm off put a freezer bag over it and then reinstall it.
then pump some compressed air into your vacum line to your fuel reg and listen for where the air is coming from.
doing this will presurise your whole engine and every vac and pressure hose on the car.
takes 2 minutes and prob solved.
You know, it'd prob be something so simple and obvious in the end! :)
Do as Dangerman says and then start at the filter and work your way thru slowly.
Could it also simply be that you've shagged the turbo?
Edited by RubyRS4
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
