  • Replies 120
Posted Images
yes i have done it several times,
if you double the bag over it will hold nearly 2 bar.
2 bar coming out thru a leak makes a loud noise so its easy to find and then fix.
who knows he may have 3 or 4 leaks.
i know last time i did it i had 2 leaks
in regards to which hose it dosent matter as long as its a vacum hose.
ie the fuel reg, a ebc, bov line, they are all about 3 - 5 mm inside diamater which fits snuggly over your air comp nozzle.
simple tight seal that you dont need to hold onto
just charge it up with a couple squirts of air and then go hunting for leaks.
Edited by dangerman4
Just had this problem on a mates R34..
I know its a pain in the arse and a bit late now if booked into Morpowa Thursday..\
but we :
Took exhaust off to see if it was blocked... it wasnt cause was still idleing shit with it off.
He then pulled all the vaccum lines and intercooler piping off and check for cracks, perished lines.
He could also hear a air leak like you and eventually found that the O rings on the injectors had perished and sucking in air..
Have you check that the actuator on the turbo is attached correctly? Had them come loose in the past also :)
Good Luck!! these things definately test your patience :)
If you get a length of garden hose (about 1m) you can hold 1 end to your ear and the other you poke around the engine bay (running or not). It will act like a doctors stethoscope and help you accuratly locate noises (vacume leaks) in places you can't/won't get your ear to.
did u check the lines off the plennum? they are after the TB so the test wont reach the plennum if that's where the issue is.
ummm think about it...
if his pumping air into a vac hose they all come off the plenum,
so therfor the whole system is full of compressed air both before and after the throttle body, its not hard to open the throttle if
your concerned about the air getting past it.
does your car sound a little like a wrx at idle?
as there were no air leaks my finger is pointed at the ringlands.
at least one piston, probally several of them.
rebuild time.
^^ thats what i was thinkin mate, would that explain the f**ked up sound on boost?
this just happend to my mates 33, ringland, and mine sounds almost identical :/
IM SORRY 2 SAY CRAIG BUT REBUILD = BIG$$$$$$$$$
OR JUST PUT A 2ND MOTOR IN THEN f*k THE CAR OFF
lol at rebuilds and serious issues.
if it's serious u will see a lot of light bluey grey smoke, if it's black u can be almost guarenteed its a little stupid niggling issue any decent shop will pick up on within a few hours if that.
sorry to here u didnt find it mate, the squirt bottle trick works to find the o ring issues on the injectors, the mist of water cause the cyl to miss fire and you can hear it in the idle easy. same thing for leaking vacuum lines and gaskets.
what colour was the smoke ?
did u notice i described the types of smoke and main causes for them earlier in the posts?
working on race cars for years i know a little bit about them....lol more then i care to sometimes...lol
but since i didnt win the lotto i have to wrench my own cars except warranty stuff.
good luck mate
i had a workshop blow piston 6 ringland on the dyno, when driving it home it it was lumpy as and it just wouldnt hit boost but didnt blow any smoke at all
im sure simon at morpowa will find the problem 4 u craig
when my rb20 did a piston, i only noticed cos of the weird sound at idle, boosted hard for the months i drove it around till i did the conversion. It never made the the sound your talking about under boost, def sounds like a turbo/zorst leak.
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
