Hi guys,
I just realise that my R33 is leaking water through a pipe on the passenger side, just beside the engine.
I have some pics to show below. The arrows indicating the pipe is the one that is leaking. I think it is water that is leaking out, dont think it's oil or coolant. Also my wiper spray (dont know if it is what u called it), the one where u pull the wiper tube and water sprays out? Stop spraying water and I have no idea where to fill the water. Can anyone enlighten me? Thanks!
https://www.sau.com.au/forums/topic/238261-leaking-on-r33-gtst/
Was your A/C running at the time of the observed water leak?
The washer reservoir should be in the front left (passenger) corner of the engine bay, the cap is right in front of the LH strut tower.
Yes I was on the aircon while driving, but only notice the leak after I stopped my car and switched the engine off. There is a big white box on the driver's side right behind the headlights, any idea what box is it? Plenty of water in it, dont know if it's the wiper water.
It was probably the water from the a/c (a/c removes moisture from the air and dumps it down the pipe you have indicated. if you get under the car, you should see it is open-ended.)
The container is probably the radiator overflow. The washer bottle might be partially hidden by the airbox.
So is it normal? Or do i need to replace the pipes? My air con blows only cold air at 18 degrees which is the lowest and at 19 degrees and above, it starts to blow HOT air. Could this be the cause of the water leakage? and according to the other thread, the problem was solved from a switch, but i have no idea where the switch is located. Can anyone post some pictures or something? Thanks alot mates!
water leak sounds normal. leave that
Hot/cold air - vent is behind the washer/wiper stalk - need to remove most of the dash facing to check it
washer bottles is a Large white bottle behiond the drivers headlight - hidden under the lip of teh guard next to that is the radiator over flow
if you still confused, post a bigger shot of your engine bay
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
