righto so most of you know i'm pregnant and am having a bit of drama with the father to be.
well when i got home from Melbourne 1 of his friends attacked me via his msn saying that
i'm only keeping the baby to keep him in my life and so i don't have to work.
oh and that it probably isn't his :D .
i went to Legal Aid yesterday and was told that a paternity test won't be done till after the baby
is born and nothing can legally be done till after it's born.
the woman told me not to contact him, which i haven't done in just over a week, changed my number
and now i have to change all my hospital appointments, if i don't change them i can tell him i don't
want him in the room (which i already knew)
not long till my 20wk ultrasound :(
Edited by pokie
https://www.sau.com.au/forums/topic/238401-my-pregnancy-thread/
  • Replies 174
Hey Amanda, hope the appointments all go well and its smooth sailing for you ... then after the crying bubs is born, all hell will break loose and you'll get no sleep :D
Listen to the advice of legal aid. They'll keep you on track. Disregard what any of the exes mates say to you. They're obviously full of it. :O
err isnt this stuff personal (between u and people directly involved). sounds like ur just having a bitch about things.. no offence.
How is it any different to you guys whinging about ex girlfriends? She just happens to be a single mum now because of a break up. If she wants to talk about it, she's initiated it, and she's the primary person involved in all this. :)
LOL yeah not looking forward to all the crying and no sleep, i barely get any now haha.
changed my number last night so won't hear anything from him or his friends. just changed all the appointments aswel
which was only 2 but still.
exactly this is no different to any whinging or bitching any1 else does on here. it may be more personal but so what it's my choice
to share that with people on here who i consider to be good friends/ people.
wow 20 wks..........already 1/2 way there!!
not quite half way yet, just under 4wks till i am :down:
when it's put into days lol yeah it does seem like forever.
but it's only 5months, which doesn't seem as long and considering i'm already 4months
it's going reasonably quick which is great, but i'm sure as it gets closer to the date time
will slow down as usual haha
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
