Yep, heard about this too.
I work for a hosting company as a product manager, and i thought of this idea..
Why dont we use a .htaccess file to detect if their IP Address is coming from know Bad IP's (i.e Police Headquarters) and set a rewrite rule to a page saying, "you are breaching T & C's of this forum, access denied." ??
I know its possible, ive done something similar myself, and would seem to prevent alot of heartache, and stop wasting tax payers money for some clown to sit infront of a computer all day surfing forums and eating donuts!
It would require identifying suspect accounts, and logging their access IP's, then we could also research where each states relevant police datacentres are located and block these IP's too.
Only way they could get around this is by using a proxy server i guess.
I guess its alot of effort, and still no way to 100% guarentee that they wont get access, but just an idea :P
id back you 100% ^^^^
Thats why its smart to edit number plates :P
I guess its alot of effort, and still no way to 100% guarentee that they wont get access, but just an idea :kiss:
Wow Great! Thanks for the support guys. :P
I can write the code for the .htaccess file and email it to one of the administrators to add to the current file.
I have no idea who i would email it to though when its done..? Any ideas guys? Also we would need people to contribute any known bad IP's.
Wow, i'd be surprised if the police were that pathetic. We keep hearing about the lack of police resources, surely they wouldn't be wasting their time looking at a forum for who has a pod filter. I'd be shocked and amazed...
Edited by Vija
Thats the irretating part IF this is true!
we will have to look out for dodgey names like Brain Earl Spoolner. See if there an under cover cop :P
Edited by Adz2332
Car modifiers/clubs/enthusiast are the scum of the earth. Their cars should be defected and owners treated like a scumbag criminal just for taking an interest in enhancing their car. They're as low as pedophiles and should have tax payer's money spent to have someone keep a watchful eye on everyone last one of them!
Your all a bunch of murderers and rapist.
Ahhh yep they do come on here for sure.
The cop at mallala actually actively goes on the R31 club forum (r31skylineclub.com) and answers questions and stuff as well as other forums too.
He does it in his own time but there is no reason that others wouldn't do the same.
I know a few of the gawler coppers as my g/f helps with blue light disco there... I reckon I know the pommie guy... usually a good bloke.
As above, I have about 3-4 mates on these forums that are police officers with imports...heck I even used to sponsor one. :(
I would say there are alot more that surf these forums especially nissansilvia.com being as it was the most viewed auto website for the last couple years etc.
Ryan
Blocking access via .htaccess seems like a good idea, but I'd be against it. You cannot say for sure that all cops that visit these sites are bad and are out to get you. Discriminate much? I've heard of all the bad stories about defects and such but as pointed out above, theres some good people in there too!
I'd propose a flag to mark them as Cops instead of blocking access, why would they have a legitimite reason to say they aren't officers? Give the something like the [has donated] tag and that way it's good PR for them, they should be representing the force in a good way and if they aren't we shoot them down! Well maybe not literally :(
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
