Hey guys,
Wondering if one of you guys with photochop skills could help a fellow skyline owner out
Dont mind if its a bit shitty spec just want to choose what rims to buy
http://www.tempetyres.com.au/products_clos...mp;part_no=1476
http://www.tempetyres.com.au/products_clos...mp;part_no=1178
http://www.tempetyres.com.au/products_clos...mp;part_no=1817
http://firesport.com.au/17-dish-wheels-whe...s--ad125931.htm
http://firesport.com.au/brand-new-18inch-o...s--ad124785.htm
Or any other 4x114.3 pattern that isnt a ridiculous price pref under $1000
Also if anyone has time, or just feels like hleping me out :(
could you put a gtr front bar or some sort of realistic body kit
Different r33 grille ( i think the one on it is ugly)
5% tinted black windows
And if someone really has time could you put a cannon on aswell
Or any suggestions you have that arent over the top
Thanks heaps !!
Nathan
https://www.sau.com.au/forums/topic/238779-help-with-photo-chop/
thanks heaps cogs!!
what do you think?? i rekon white looks the best in terms of rims
Could you do a chop of the stock front bar with that new grille you used as i dont think the gtr front bar looks the goods, although i like the grille.
Thankys again!
No worries Natho. I liked the white wheels best also. Here's a chop of those wheels off ebay.
I also did a chop of the GTR bar with the white 18s on (just to make sure it wasnt the old wheels putting u off the looks of the front bar) and a chop of the stock bar with the GTR grill.
you should check out the following:
http://www.skylinesaustralia.com/forums/Wh...re-t215749.html - Whos got the best looking NA here
http://www.skylinesaustralia.com/forums/Po...33-t130489.html - Post Up Your 33!
both are big threads with lotsa photos and ideas. helped me a bit in doing mine up :/
gl hf
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
