Item: 1. custom low mount turbo manifold for rb20/rb25det hpc coated 2.6x gtr coil packs
Age: 1. manifold 5 months.2 gtr coil packs i have owned for 3months
Condition: 1.perfect 2. also perfect doesnt miss a beat
Price: 1.250 ono 2.250 ono
To Fit: (What car) both items will fit rb20det rb25det
Contact: via pm or emial [email protected]
Comments: selling these items as ive sold my car price is nego
Edited by MIZSKYJET
https://www.sau.com.au/forums/topic/238805-vic-rb2526-goodies/
