Hey
I went to the mechanic the other day and he said the turbo was leaking, something to do with the manifold. The effect of this was that i was losing power and boost, and u can hear air coming out instead of in from the engine bay. He quoted me $380 and i have to leave the car overnight, is this a decent price or am i gettiing ripped.
Any help appreciated..
thanks
will
https://www.sau.com.au/forums/topic/23889-turbo-leaking-losing-power/
i had a leaking problem too about 6months ago. mine was making a screaming sort of sound at full boost and was losing power.. mine was from where the turbo bolts on and all i had to do was tighten up the bolts half a turn each and only took 10mins... might be worth checking that first b4 you pay that sorta money for something that might be this simple
sounds like a good idea....just one question, im not much of a mechanic...how did u get down there to tighten the bolts, which bolts? like do i have to take out anything before hand .... Cause i know the turbo is low mounted, but don't really know how to get access to it....
umm im no mechanic either so this might not help you much.. but i remember taking the heat shield off and there was little metal clips covering 1 side of the bolt so they couldnt turn.. so after bending the clips back i just tried to turn the (not %100 sure how many) 4ish bolts tighter b4 bending the clips back over so they dont turn back at a later stage... i left my heat shield off which im not sure was a smart idea.. but it made putting the dump pipe on a bit easier.
What happened was that i lent my car to someone, who cracked the front bar, not sure how it happened, but the mechanic said that may be the cause for the problem in the manifold... not exactly sure of the seriousness of the problem atm ... but will check it out next week...
Jetdat - hopefully it is...save a bit of money, lolz
thanks for all the replies
btw...anyone in Sydney know of a good mechanic to go to to have it checked out, i've been to fussys and got quouted 380...but he did not explain seriousness of the problem, but just saying that he needs to have the car overnight...
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
