Hey Guys,
Been Doing some reasearch on chassis foam for the rails in my R33.
Now most of us know that ye ole skylines arnt exactly stiff in the chassis department, I can hear the hole car creak and grown when crossing driveways etc.
Has anyone used the expanding foam in their cars and what exact foam has to be used. I know you can get stuff from the local hardware store but am unsure on:
a) How Much to use in the rails (i.e dont want the rails to split with the pressure)
b) What type of expanding foam do I use
c) Is it worth while (would surely be better than a strut brace and more than likely cheaper aswell)
I've tried searching google but there are no real definitave answers to the questions
EDIT - Just Found This - http://forums.nicoclub.com/zerothread?id=270721
Regards
Andrew
Edited by zebra
https://www.sau.com.au/forums/topic/238975-chassis-foam/
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
