Make:nissan
Model:r33 gtr v-spec
Milage:30,0000
Transmission:m
Colour:midnight purple
Complied?y
RWC supplied??
Currently registered?Yes 1 yr
Price:$34,0000 not nego
Contact: pm or 0438462833
Comments / Modifications:
has n1 block, n1 oil pump, n1 water pump, forged pistons, all r34 engine componets etc, gold top motor. have adjustable cam gears, after market front pipes. engine has done 30,000 scince rebuild and turbos.water, intake,voltage,boost gauge's front rda slotted rotors, twin plate clutch, front race pads + got spare stock front pads and what ever i missed
Images:
https://www.sau.com.au/forums/topic/239011-r33-gtr-v-spec/
Well I guess I'll be first to put up my hand and vouch for this car, don't sell it Mitch!
Guys and Gals if you want a really nice midnight purple GTR with a forged engine rebuild already done for you, then buy this car. It's always been looked after mechanically and the paint is in great condition. You won't find a better condition GTR for this price.
Good luck with the sale Mitch though it's a shame you're letting her go, ther'd better be a good reason.. :thumbsup:
https://www.sau.com.au/forums/topic/239011-r33-gtr-v-spec/#findComment-4176603
  • 1 month later...
i seen your car a few times now and been behind it on a few cruises, your car sounds nice, if i had the money i'd definately give it a good home mitch....
sorry to sound like a tosser but i can't afford both cars and it'll take ages to sell my skyline in this financiaL climate so if you need something quick,
best i can do is swap with money going your way with my 96 r33 gtst,,,, i don't have enough money for 2 skylines. got a gtr bar so you don't miss your gtr too much...been stock untill recently, put front/dump pipes about 5000km ago, literally done 50km on 10psi boost, put boost, water oil temp gauges and fmic last weekend, throttle body cleaned, afm checked and cleaned, new platinum spark plugs, had oil changed 3 times in 13000km, changed 02 sensor (get about 450-500km to empty).... also go through my posts about my car and you'll see it hasn't even done a burn out yet and ive had it for nearly a year lol, cars done 79000km. Very good original paint, still glossy... $2000 sound system i dont use much anymore...
If your interested pm me, or tell me to get stuffed.... either way i'll be at dyno day on saturday if your there...
iff not i hope you do find somebody who will buy your car.
cheers mate
https://www.sau.com.au/forums/topic/239011-r33-gtr-v-spec/#findComment-4255491
$29,990
contact: max 0430283377
or 97460100
[email protected]
tell them your interested in the r33 gtr. rego AW-80-UA
http://www.nationalcarconnections.com.au/i....php?car=buying
https://www.sau.com.au/forums/topic/239011-r33-gtr-v-spec/#findComment-4275539
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
