Hi Everyone,
I recently got a letter in the mail from the EPA, for a full emissions control test. I have a GTR 33 fully built, basically everything modified. I know its going to fail, but does anyone have any advice / ideas on what I could do to help it pass? I was thinking of just changing engines and returning everything to stock. Thanks
Edited by Evos33
https://www.sau.com.au/forums/topic/239278-epa/
Hi Everyone,
is it emissions as in db emissions (sound level)?
or emissions as in (pollution)
because even if you throw a standard motor in it and the test is for pollution emissions. that wont pass either, the motors are just to aged and wont pass no matter what
if its for sound your ok you'll get it sorted easily.
otherwise cancell your rego and sell the car to your brother or mum or someone then get them to sell it back to you and your car MAY then be defect free? I did that 2years ago and got away with it. laws may differ now
Or last alternative, never fails is take down a wallet full of green coloured notes. that will change any assessors mind.
Edited by JET26R
https://www.sau.com.au/forums/topic/239278-epa/#findComment-4180497
Doesn't work anymore... loop hole closed...
There's a guy on here with a fully modded 33gtst that past emissions, power fc tuned buy himself... he should be able to give you some advice...
https://www.sau.com.au/forums/topic/239278-epa/#findComment-4180579
Im assuming thread started is in Vic (sounds like it by his post)
And if thats right, then Guilt's car has no relevance here because NSW & Vic Testing/Requirements and so on are at totally different ends of the football field when it comes to these things. There is no parity between states
https://www.sau.com.au/forums/topic/239278-epa/#findComment-4181481
I recently went through this fiasco, And you If you are getting a full test done, you WILL NOT pass with any mods, except. you are allowed 1 Intake mod, i.e Air filter or either Inter cooler only one of the two. An Aftermarket Exhaust is allowed only if you think It will pass Emissions and Noise test. And you are allowed Turbo Timers too. Anything Else = FAIL
https://www.sau.com.au/forums/topic/239278-epa/#findComment-4182223
fail fail fail fail fail, no chance in hell of passing the emissions test, stock or not stock, youll never get to the level needed.
their might be a chance of passing, it might be your only way as i know somone that has done it,
PM me and ill let you know what it is, but have to keep it on a need to know basis, to many people knowing will close the loop hole.
https://www.sau.com.au/forums/topic/239278-epa/#findComment-4182275
ive passed a 240rwkw r33 thru a full emissions test in nsw,
engine bay looked totaly stock except for the front mount which didnt affect it
i just had a real good tuner who was able to get the right numbers that i needed to pass the test
https://www.sau.com.au/forums/topic/239278-epa/#findComment-4182401
I Passed With A shit load of Mods was running somewhat 310kws , Turbos , Ecu , fuel pump Filters ETC. It an b Tuned , in sydney HITMAN in penrith can help He tuned my car in 2 Hours and passed it 30 minutes later , but if your in melbourne you need to find a tuner with a gas analiser Machine that can tune you car to pass ....
if you need any more info pm me me or ive got a topic on this and as someone stated before guilt toy on here also tuned his car and passed , He also helped me with mine :O
Edited by MRGTR911
https://www.sau.com.au/forums/topic/239278-epa/#findComment-4183008
*sigh*
Did you pass in Vic? No.
Gazzilla is spot on the money. The cost alone to pass in Vic is ridiculous. Its a FULL lab test (and not just one test). Its the test all new cars go through before ADR approval.
Not some gas sniffer on a dyno etc etc.
https://www.sau.com.au/forums/topic/239278-epa/#findComment-4183027
*sigh*
well i done get it over here in sydney its easier your saying ???? so your sasying in melbourne even if you got it tuned it still wont pass???
https://www.sau.com.au/forums/topic/239278-epa/#findComment-4183035
    • I'm going to slap an old nismo logo sticker on my spare one and sell it to the land of the free for a thousand bucks
    • lol, probably should have read further!
    • Well - they have arrived.  And they are easy on the eye to put it mildly... These only have three bolts - but for a start there is a key that fits with vacuum like precision..  And as you can see by my ruler, the interface is large..   I listened to a podcast on HP Academy about Dan (KiwiCNC) and I'm more than comfortable he knows what he is doing. R35 Bearing assembly should arrive later today so can mock that up for a look. Can't wait to get these on and get some brake pressure logging too. IMG_3860.MP4
    • I would be very confident that they are the same parts (the 2 different SKUs). It seems very clear that you can drop the cam in the 2-way opening, or in the other opening. If you arrange it in the other opening in the same way that you see any other 1-way diff, ie, with the flat of the cam up against the 1° side of the opening, then it would work as a 1-way. It can only spread the ramps when driving forwards - cannot spread the ramps on overrun. It would then appear obvious that if you put the cam into the opening "backwards", that you would get the angled flats of the cam working onto the "points" of the 1° side of the opening, which would give you ramp spread in both loading directions. I do wonder if the forward direction of the 1.5-way config is equivalent to the forward direction of the 2-way, seeing as the cams are flipped and the angled surfaces on those would need to be the same on each side - AND - clearly when installed in either the 2-way or 1-1ay configuration they are not intended to work exactly the same (the ramp angles on the 2-way are 10° different between forward and backward, and the ramp doesn't exist in the 1-way config). 'twere me, I think I would rather actually have a set of rings that offered the 2-way with two different sets of ramp angles, say the 55/45 of the existing design and maybe a 45/37.5 combo for a less aggressive effect), AND another set of rings with a dedicated 1.5-way opening and a dedicated 1-way opening. The 1.5-way opening would actually have the steeper angle on the overdrive side that causes it to be less pushy than the forward drive angle, like you see in many other diffs. But really - if this Nismo thing is thought out properly and all those surfaces work on each other the way that they need to, who am I to argue?
