Have not heard of or used this product but will be installing a data logger in my R33 race car soon I am useing a ruzic engineering data logger Paul the guy that makes them is in the final stage of finnishing the production model should be a verry good unit with local support and back up as well as future software upgrades. check his stuff out at www.timeattack.com he is also a user on this forum user name mountainrunner and one hell of a nice guy. I think his unit will do everything you require.
https://www.sau.com.au/forums/topic/239380-datalogging/#findComment-4182724
doubt Paul's data logger has anything to do with GPS or lap timing.
I saw a thread on the same thing over at the IPRA forums earlier in the week - might be helpful:
http://www.techmasters.com.au/forum/viewto...?f=2&t=3802
https://www.sau.com.au/forums/topic/239380-datalogging/#findComment-4183815
what about the v-box mini? it looks identical to the perfomance box, but you can get a modual to put inputs from the car into it.
Not seen that before. Rpm traces tell you alot as do TPS & others. Shame no one makes it easy to tap into the few extra inputs that can add so much useful info.
Anyway the performance box is <$1000 but so is the Starlane gear too. The Starlane stuff appears to have more functionality for the dollars.
https://www.sau.com.au/forums/topic/239380-datalogging/#findComment-4183938
i got my datalogit box to log front torque %, was going to get round to logging brake (unfortually the brake is a 24v switch) and steering angle. If the Datalogit had memory it would almost be perfect, cause i'm not a fan of laptops floating round the car at the track.
https://www.sau.com.au/forums/topic/239380-datalogging/#findComment-4184010
vbox mini is the driftbox. performance box is the cheaper version of that without the yaw sensor. can get the performance box for $850 from Racer Industries. Its a little bit pricey for what it does in lap timing mode - lap time, up to 6 split times and speed at splits.
https://www.sau.com.au/forums/topic/239380-datalogging/#findComment-4184145
Yes my Logger does do GPS and Lap Timing. Buts thanks for the usual uniformed commentary hrd-hr30. One day you will get over the AWD Shoot-out incident and stop trying to sledge me. lmao.
On a more serious note, there are a lot of loggers on the market these days and they all have their pro's and cons. Its about finding one that best matches what you are trying to achieve. For driver analysis you probably want to be at least logging; Throttle Pos, Steering angle, LatG, LongG, RPM, Speed, GPS is good for lap times and driver lines easy split times etc.
I've built my logger because I like to build electronics for cars such as my Torque Split Contoller and new Engine Monitor. I spend the extra time to make them marketable because a lot of guys who see what I'm up to want one and it also helps pay the development costs. The other thing is, when I've built the system its easy to modify it and enhance it with feedback from myself and other users. Its always nice to be able to add a feature or function when it can enhance the product.
For comparison I have loaded the current specs into the other Datalogging thread I started a while ago. These are the specs the beta system will have on release. There is a bit of detail there but as an overview:
10 x Analog Inputs (6 at 20Hz and 4 at 25Hz)
2 x Rate Inputs (RPM, Wheel Speed etc)
2 x Digital Inputs (brake pedal, clutch etc)
4 x Outputs settable as less than or greather than on any channel
GPS Input at 1Hz or 5Hz for track mapping and lap timing. This is also output to my Engine Monitor if it is connected.
Logging is done straight onto a USB key. No downloading and no memory constraints.
There is USB connection to the Laptop for configuration. (but not needed in the car as you point out sav_man you dont want to have to drive around with it)
6 of the analog channels can be used to sniff off factory or other system sensors, so no need to double up.
4 of the analog channels have build in 1K drive resistors to run sensors like Oil Pressure / Temperature which are not usually on factory cars (not good ones anyway)
I've included a serial port to connect the RaceLogger to my Engine Monitor so you can expand the logging to included all those channels also (6 more analog, 2 more rate). Plus the Engine Monitor can then display data from the RaceLogger.
Also you can daisy chain my 4WD Controller serial signal into the serial port of the RaceLogger and log the LatG, LongG and 4WD Split.
The data analysis sonftware will be an open development feeding in all ideas etc from the users of the system. I'm looking forward to seeing where we can take it.
https://www.sau.com.au/forums/topic/239380-datalogging/#findComment-4184190
From what I have tried I have found that GPS based position information if much better than the accelerometer based data simply because it allows you to plot your speed trace versus distance which is much more usefull than having it versus time. It highlights the small gains you end up looking for.
https://www.sau.com.au/forums/topic/239380-datalogging/#findComment-4184210
The accelerometer data is very useful when looking at oversteer/understeer for in/through/out of a corner. It really depends what your looking for, which makes up the best combination of sensors for a given analysis.
Sorry I may not have explained myself well enough. You can easilly derive acceleration data (ie lateral & longitudinal) from GPS position data. What I was trying to say was that presented graphically it is more useful when plotted against distance than against time.
It makes it easier to see what was happenning at a certain point on the track rather than a certain time into the lap.
Hope that makes sense. :kiss:
Straightforward accelerometers don't do distances well because they get messed up by hills & gradients etc.
https://www.sau.com.au/forums/topic/239380-datalogging/#findComment-4184468
well laughing boy, maybe I should have been clearer. it doesn't have built in GPS fuctionality like the other units being discussed.
but it CAN log GPS and lap times, IF you connect an external GPS unit, and you can even see your lap times on the fly like any other lap timer IF you add the engine monitor.
anyway, lmao right back at ya if you actually mean what you said - lap timing at 1 to 5hz.
1hz = timing to the second
5hz = timing to 0.2 of a second
I think most people would be looking for tenths as a minimum resolution for lap time information to actually be useful/meaningful. So it doesn't really do lap timing either.
https://www.sau.com.au/forums/topic/239380-datalogging/#findComment-4184911
You were never going to win the AWD Shoot-out dude. Let it go. Breath in, breath out. Drink a soothing tea. Again LMAO at your persistence at sledging me, its the funniest shyte I read on the forums. Seriously dude let it go. No one cares. Try to contibute positively to the community instead.
By the way, if you think the speed the GPS data arrives is the same as the accuracy it can lap time at, then perhaps you should keep out of the technical discussion.
https://www.sau.com.au/forums/topic/239380-datalogging/#findComment-4185692
if you're using GPS signal to determine where the car is in relation to a start/finish line, and you only know where the car is at best every 0.2 of a second, you have a resolution of 0.2sec with an accuracy of +/-0.4sec as you have to cross that nominated start finish line twice per lap to start and stop the timing. Any times you give to an apparently greater accuracy are just approximations based on interpolation of the data - at best.
https://www.sau.com.au/forums/topic/239380-datalogging/#findComment-4186003
Yea it would do. You can get 5Hz GPS for a reasonable price. You just have to decide on the precision and accuracy as well at purchase.
As I was saying above, the timing accuracy is not just based on the GPS location data. You also use the equations of motion and most also use GPS-INS techniques. Its pretty mature technology and you should look at the specs on the system as a whole and not just a sub-system of the device.
https://www.sau.com.au/forums/topic/239380-datalogging/#findComment-4193994
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
