I'm after some replacement headlights for my Series 2 R33 GTS-T one of the lights has a few cracks on the inside and both are pretty dull even after giving them a good clean and sanding them back and polishing.
I was just wondering with so many ppl complaining about the clarity on there headlights if there are any aftermarket brands that make bolt on lights for skylines?
https://www.sau.com.au/forums/topic/239434-after-market-headlights-for-s2-r33/
Im pretty sure there are some after market ones..
Although theyre not cheap!
Any Chance you know some brands or have any idea who i would ask about them :kiss: Ive looked around a called a few places but no one knowns about them. Are there some more specialty places that would stock this kind of thing?
There is a guy in the US that converts your stock headlights to projector type ones, though this process is very expensive its a hell of alot cheaper than buying the OEM projectors that the series 3 GTRs came out with.
www.IznTrbl.com
This is step 1: http://au.youtube.com/watch?v=imIiglkq7HA&...feature=related
Go through all the steps to see this guys handy work.
    • I'm going to slap an old nismo logo sticker on my spare one and sell it to the land of the free for a thousand bucks
    • lol, probably should have read further!
    • Well - they have arrived.  And they are easy on the eye to put it mildly... These only have three bolts - but for a start there is a key that fits with vacuum like precision..  And as you can see by my ruler, the interface is large..   I listened to a podcast on HP Academy about Dan (KiwiCNC) and I'm more than comfortable he knows what he is doing. R35 Bearing assembly should arrive later today so can mock that up for a look. Can't wait to get these on and get some brake pressure logging too. IMG_3860.MP4
    • I would be very confident that they are the same parts (the 2 different SKUs). It seems very clear that you can drop the cam in the 2-way opening, or in the other opening. If you arrange it in the other opening in the same way that you see any other 1-way diff, ie, with the flat of the cam up against the 1° side of the opening, then it would work as a 1-way. It can only spread the ramps when driving forwards - cannot spread the ramps on overrun. It would then appear obvious that if you put the cam into the opening "backwards", that you would get the angled flats of the cam working onto the "points" of the 1° side of the opening, which would give you ramp spread in both loading directions. I do wonder if the forward direction of the 1.5-way config is equivalent to the forward direction of the 2-way, seeing as the cams are flipped and the angled surfaces on those would need to be the same on each side - AND - clearly when installed in either the 2-way or 1-1ay configuration they are not intended to work exactly the same (the ramp angles on the 2-way are 10° different between forward and backward, and the ramp doesn't exist in the 1-way config). 'twere me, I think I would rather actually have a set of rings that offered the 2-way with two different sets of ramp angles, say the 55/45 of the existing design and maybe a 45/37.5 combo for a less aggressive effect), AND another set of rings with a dedicated 1.5-way opening and a dedicated 1-way opening. The 1.5-way opening would actually have the steeper angle on the overdrive side that causes it to be less pushy than the forward drive angle, like you see in many other diffs. But really - if this Nismo thing is thought out properly and all those surfaces work on each other the way that they need to, who am I to argue?
