would be interesting to know how much thrust it really puts out. my mates brother in law has got a propper model aircraft jet engine, and he had it bolted to a big heavy wooden table (the kind that takes a few people to move), and he started to spool it up one day, got to about 15% throttle i think it was and it started moving the table.... with two big blokes at the front of it trying to stop it moving. theres some pretty serious shit out there in relatively small packages.... only question is how to mount a gearbox to the back of one lol
https://www.sau.com.au/forums/topic/239529-turbojet-engine/#findComment-4187103
You can find instructions on the net. The outlet of the compressor is fed to the exhaust inlet, mixed with fuel and ignited.
yeah have seen some instructions on the net seems easy to do....
outlet of compressor goes to a combustion chamber then to exhaust inlet. need to have a sprk plug in the combustion chamber
to ignite the LPG.
but need to know what sort of pressure is safe to run in the combustion chamber without blowing the turbo apart :(
and also what sort of oil pressure i would need to run for the turbo.. im thinking it would need a good oil cooler too.
i have read that you can get these things revving to about 130,000 prm :ermm:
https://www.sau.com.au/forums/topic/239529-turbojet-engine/#findComment-4190339
but need to know what sort of pressure is safe to run in the combustion chamber without blowing the turbo apart ;)
i have read that you can get these things revving to about 130,000 prm :)
pretty thick cast iron with a gaping hold in the back of it (where dump pipe normally goes/where thrust is generated) i rkn you could get heaps of pressure in there no worries.
and turbos spin well past 100,000rpm on your car anyway, what you've mentioned isnt anything crazy
https://www.sau.com.au/forums/topic/239529-turbojet-engine/#findComment-4190393
Well there are two main ways of doing it. You can connect a shaft directly to the rotating center of the jet turbine and feed it through a huge reduction gear or you can use the outbound trust to turn a "windmill" feeding a smaller reduction gear. The yachts I work on, some have jet turbines, they're great! little maintainance, produce masive amounts of HP in a very small package.... great for getting your 600gt 200+ft yacht to do 40+knots (and engine room fires!) and they run on straight diesel!
As for an automotive application, I would use it in conjunction with your piston engine. Use a "windmill" connected to a reduction grear, to an electromagnetic cluch arrangment, drive shaft, feeding a modified gearbox... hmm
Hell you could probably have a go at feeding the power to the front drive transfer case on a GTR gearbox... for a laugh!
Justin
Edited by XRATED
https://www.sau.com.au/forums/topic/239529-turbojet-engine/#findComment-4192370
im not familiar with jet engines and jet turbines, i know they use one in the y2k jetbike, and they use em in helicopters and tanks n shit, just didnt know they were the same sorta thing, how do they do it in choppers and tanks and stuff?
https://www.sau.com.au/forums/topic/239529-turbojet-engine/#findComment-4199856
I'm fairly shure the y2k was a direct shaft drive through a reduction gear (2 speeds- faster and stoopid fast) with some style of "buffer" or "slipper" clutch... Tanks are either multi geared (auto trans) direct drive, or hydraulic pumps and motors driven from the turbine and choppers are either direct drive or the turbine drives a generator that creates DC power to drive an electric motor coupled to the blades.
https://www.sau.com.au/forums/topic/239529-turbojet-engine/#findComment-4200992
so how fast do these bigger motors spin? like in the y2k or in choppers/tanks? what about the diesel ones in the yatchs?
18000-25000 rpm is the upper working range of the larger units I've worked with. Helicopters probably more... Y2K less.
https://www.sau.com.au/forums/topic/239529-turbojet-engine/#findComment-4203280
The hard thing is getting the flame holder right, you want it to burn all the fuel before the turbo but not blow out the flame when giving it some throttle.
Here's a good link for a really basic one - http://www.junkyardjet.com/primitive.html
And finally, a good use for a spare set of N1's ;)
https://www.sau.com.au/forums/topic/239529-turbojet-engine/#findComment-4204884
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day
    • While I was waiting for the new parts to come in for the charge pipe and radiator I decided to do some turbo modification. The drive pressure (exhaust backpressure) was a lot higher that I thought it should be. For 32lbs of boost drive was 55lbs. The turbine housing is a 1.10AR and my turbo builder has suggested to go to a 1.25AR. To test if a larger AR would do anything to reduce drive pressure AND not spend any money I decided to hog out the divider in my current housing. I removed it from the inlet and the whole way through the housing.  After reassembly and testing it doesn't look like this modification did anything for reducing drive pressure or requiring more fuel (making more power). Oh well, it was worth a shot. We'll get some data at the track if it makes it past the 60ft. I also machined a $7 shift knob off Amazon to fit my Stillway shifter since I didn't like the Stillway shift knob. Next on the list was the radiator replacement and fabrication of a new intercooler tube that had no silicon coupler. No pictures of this - I was short on time each night after work to get this done and didn't stop to take pictures.  Next was to get the clutch disks out and replaced. Previously when installing the dogbox I had ordered a set of the same sintered iron disks I had been running because I switched to the 26-spline input shaft. I thought it was odd that they didn't have any markings or brand name on them like all my old disks had but installed them anyway. At the track I could not get the clutch to lock up using my normal strategies. After two track nights I reached out to the clutch manufacturer and ask their thoughts. They said they had to switch the material out because they were having trouble getting the original material and that this new material would not take to being slipped very well.  So out with the first set of 26-spline disks and in with the correct material 26-spline disks. While I had the trans out I added an inspection/service hole. I've wanted one of these for a while. Now I can have a look at things and change the front cover shimming when needed (clutch wear). I hustled and got the clutch change done in a few hours on a Saturday. Hopped in the car and drove home. On the way home I did a 1-3 pull. When shifting from 2nd to 3rd the core plug in the back of the cylinder head popped out and dumped all the coolant. Thankfully I was only 30 seconds from home and coasted it there. Datalog showed nothing unusual and 2.5psi of coolant pressure. That plug has been in there since 1992 but I guess it worked its way out. Pulled the trans AGAIN and replaced the plug, JB welded it in, and made a brace. Also deleted the head drain I had added in during the bearing issue fiasco.  I am currently changing my boost control plumbing to make it cleaner. After that is done I'll make another attempt at getting past the 60.
    • Are you 100% sure this isn't tune related?
    • 140-150 across the board. At this point hoping the grounding harness fixes it. My grounds are all tied to the chassis and none to the battery. For SR and KA that’s never been a problem for me but had a few other guys here and Reddit who told me RB really like a very solid ground setup tied to the battery so going to try that next, I’m stumped if that doesn’t do it. Never had a car have spark and fuel and not fire off before. Only thing I can think is the spark is intermittent/weak because of grounds nothing else really makes sense at this point
    • I am having close to the same issue. Can you help me with what wire you grounded to get your pump to trigger?
