hey every one i have some 2 door r32 gtst parts for sale all parts are in great condition some things have a few little scraths but are straight will be available from tuesaday onwards as im goin away for weekend.
2 r32 bonnets one black one white im chasing 120 each for them
2 pairs of guards one pair black one pair white i want $100 for each pair ... on pair on hold
2 rear stock bummpers one white one black offers $
front standard sway bar $50
https://www.sau.com.au/forums/topic/239738-r32-panels/
  • 4 weeks later...
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
