Had a dual stage boost controller fitted today.
I wanted high boost to be 14psi and low to be the stock 7psi. However for some reason my mechanic couldnt get low boost below 11-12psi.
Does anyone know why this could be? He suggested that possibly the car wasnt running 7psi when i brought it in, however to my knowledge it hadnt been boosted before...
Mods include large FMIC, 3" turbo-back exhaust.. (if that makes any difference)
Any suggestions on why the boost would not come down would be most appreciated...
https://www.sau.com.au/forums/topic/23975-boost-problem-on-r32/
With everything dead stock inc. the cat convertor that was no bigger than my fist the boost was hanging around 8-9psi and made 115rwkw, 125rwkw with the fuel pressure tweaked to lean it out a little.
I then slapped the exhaust on and it made 10.9psi.
Then the bleeder was fitted and it bumped low boost setting up to around 11.5-12psi. With the fuel tweaked it made 152rwkw on 12.5psi. Low boost and high boost felt hardly different with highboost mainly having a bit more in the mid.
I then fitted the ebc and found that it was the restrictor that was causing the boost to hold a little higher.
With the EBC it is now back to 10.9psi.
16psi on High boost, I never drive it on low boost as it feels to gutless.
The RB's love boost :P
nah its those crappy turbosmart controlers.
i had the exact same problem as you, couldnt run less than 13psi with either a 2 stage or a bleeder. wheni removed it all together i could hold 8psi and i have cooler, exaust, dump, filter.
i think the valve cant seal off properly or something.
by removing it or changing to ebc there was no probs in running std boost levels.
Hang on i thought R33s ran 6psi and R32s 7psi (certain of that because the factory boost gauge says 7)...
Anyway when my mechanic cable-tied the tube to the b/c (thus "removing" the b/c), it showed stock boost levels.
Benny i think you're right these cheap b/c's cant seal properly.
Mine peaked at 12 then dropped to 10 with front mount, pod and exhaust, no controller.
Turbo smart peaked set to peak at 14 then dropped off to 10 or 11 cos stock wastegate couldn't hold, NO SPIKES. Low boost setting went up to 11psi dropping to 10.
HKS actuator fixed that. Got it set at 12 flat in low boost mode, peak at 15 in high dropping to 13.
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
