Hey guys,
as the topic suggests, WIll I need to calibrate my speedometer and some other parts to compensate for lagrer rims?
I have a R34 Non-turbo. Stock rim size is 16 inches. I have 17 Inch rims on at the moment.
I want to put 350z rims on them, which are 18 inches.
Thanks,
Shane
https://www.sau.com.au/forums/topic/239769-speedometer-calibration/
Rim size has nothing to do with it. It the overall wheel diameter (rolling diameter).
You'll notice that 18" wheels have a lower-profile tire, compared with 17/16/15" rims?
Any half decent tyre+wheel stockist will look at your tyre plakard to work out the stock rolling diameter, and then find a suitable tyre profile to maintain the diameter as close-as-possible.
You wont need to touch your speedo.
i have 18" 350z rims on my r33
im running 235/40/18s on all fours which keeps my speedo pretty darn close to being correct.
its out like 0.5% or something
that should give you something to go by, instead of just relying on the tyre guys word.
also google for wheel size calculator or something similar. there is a site that will work it out for you
thanks Trav, thats what I've mostly been reading on the internet.
much appreciated.
Here's one for you, Shane.
http://kumho.com.au/tips_diameter.htm
Punch in the details of your current tyre package, and then find the dimensions of a set of 18's that have the same or similar rolling diameter.
Thanks Nick, ive used that to check...
the new rims are 108 and 164 mm larger in front and rear rolling diameter, respectively.
What difference will this make??
wow thats a 5 and 8% change in rolling diamtere. it says +/- 2% is a safety net. think ill need new tyres
Lower profile tyres will compestate for the larger rim as said above. No need to calibrate anything.
IT will go out by a very small percentage tho, maybe 0.5kmh. Nothing to worry about at all.
Tho from stock, the factory makes the speedometer read faster then ur actually going. Ive tested with my apexi rsm. At 100kmh you are actually going 97kmh. At 110kmh you are only going 104kmh. Something to do with safety...
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
