  • Replies 46
likewise but i cant afford a luxury car wash :spank:
and cbf hand n bucket right now , so hot
hiv u got a buckit and a hoose brew? the cars parched as...
just got back from washing my car at dazzlers... for some reason i can never get the exhaust dust off the rear bumper (and being white, its very noticeable).... anyone got any tips? I've tried bam which helps but doesnt really do a full job
-D
-D
i used some clay block thing from a car detailers place. all the exhaust crap and the glaze on the bumper came right off. amazing.
-D
do YOU have any plenktum ?
Well just got home from mates house. Went over there about 12 where everyone was. Took my mate and his girlfriend for a drive in my new car to the swervo for a Mother, came back then went with two fo my mates (Kahli R32 and Mike R34) for a bit of a cruise, caught up with a Supra, R33 and WRX then went for a bay cruise (WTF! Traffic banked up from end of Jetty road back to the lights!). Then went to beach with all the cars to see my friends, then thats about it, showed off my car to my mates, gave them a ride, hung around and got a bit red from the sun.
School tomorrow...
-D
the stuff on ya bumper is a burnt fuel etc mark,u'll have to polish it out,used to detail cars,and had it being a constant problem
-D
Just use some polish, i did the back of Kellies car, only took about 5 minutes and came up like new :ermm:
Hrm
I'm lazy. I'm gonna try the gumption and then perhaps just pay someone to detail mah car. Has never been detailed since I got the car, so probably about time I get it done... do detailers repair paint chips and what not?
Anyone got any detailers they can recommend ?
-D
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
