I just installed a Tomei Technical Trax 2-Way with a 3.9:1 final drive.
I like the final drive. I'm not so sure about the high yaw clunking of the LSD itself, since my goal with the car was a streetable car that could be tracked.
I'd really like a Quaife, but it's well out of my price range.
is your car auto or manual?
Mine is auto..... most people would tell not to bother... but i want exactly what you are after a streetable car that i can also take on the track....
Apart from the clunking... did you get the extra downforce power?
Edited by V35DRIVER
Manual.
The rest of my car works for my goal. The only change I make for track days are the rims/tyres. Its not too noisy, its not crazy stiff, I've got a stock interior, the pads don't need heat to work.
As for the LSD, I haven't noticed much of a difference yet as I've not really opened the car up. When the rear breaks away its lost a lot of its progressiveness. It gets a lot more sideways a lot quicker, which was a bit interesting the first time it happened.
When I gave the throttle a prod around a roundabout in the wet on Tuesday it didn't break traction where it would have with the OEM VLSD.
I'll give it a couple of months of street driving, and at least 1-2 track days, before I make a final decision on whether I like it or not.
Edited by scathing
Thanks for that info...
I think before i go the LSD i am going to go the cheaper option and get set of Selby's sway bars for extra downforce...
The guys down there (superior suspensions) say they have created a system which really makes a difference to the handling of the car......
When your heading out to the track next, let us know....it might be good to get a few vq35's going round...
Sway bars are the single best handling upgrade for the car. I'm not sure about the V35, but on the Z33 the ride/handling compromise for the coilovers is almost spot on for a daily driver that only occasionally gets tracked once you do the bars.
Does your car come with the VLSD? If so, there's plenty to do before you upgrade it. Honestly, I didn't really need a new diff as the old one was still holding up OK. If I tried to slide, both wheels would light up. It was only around the tightest of hairpins that it would single peel.
My next definite track day is Circuit Club's 5th Year Anniversary track day at Wakefield - but it will probably be really busy.
yeah it comes with the VLSD... im going to do the sway bars within the next few weeks... just got to get a spare moment.. im always on the go... ive also finally located a full manual 6speed box out of a Z... so also thinking about putting that into my V35... but before i do that - i want to test drive a 6speed v35 ...and see the difference.... if its major im doing it... if not then i will just leave it...
The auto is a 5 speed, right? That means you'll be running a 3.2:1 final drive. If you do a gearbox swap without changing the diff ratio, you still won't see the acceleration of your manual brethren.
I always thought that if I was to go FI I'd run that 3.2:1 FD, but so far I haven't seen too many turbo owners in Australia looking at doing a swap. The only guys I've seen even consider it are in the States, making big power with built engines.
  • 3 months later...
Hi Guys sorry to bring up the Old threads.
Does the CPV35 Premium Auto comes with LSD? Some people said no but some people said it does come with VLSD. Kinda confused here. Mine is 2003.
cheers
Yer, I've brought this up before on this forum, I have an 03 prem auto coupe also, the story is all 5 speed autos are ''NOT'' fitted with VLSD's, anyone who has got it must be fitted with an after market Diff! Just jack the rear end up and turn the hoop's to find out. Forgot to mention also, all auto 5/AT 350z's ''ARE'' fitted with VLSD's as STD were the V35's are not, bit strange when both run the same drive train and the same design platform, maybe Nissan has some reason for it, anyone else got some answers.
Does this trick work with VLSDs? I just figured the fluid was so slow to react that a hand-turned wheel couldn't make it harden.
I never tried it with the stock VLSD so I wouldn't know.
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
