just checking if anyone has been unwell recently like me?
about a month n a half ago i had the flu really bad.. i had it for about 10 days! i eventually got better and went on a holiday over to thailand (phuket). while i was over there i got sick again.. this time i had a nausea sickness. total loss of appetite, bad stomach pains and really bad dhiarrhea! i had it for about a week.. even when i returned home! i thought it was from eating something bad over there..
i have been feeling well for the last couple of weeks until friday night just gone.. the nausea came back and i have lost my appetite again.. pretty much the same as when i was on holidays! i had a really bad sore throat last night, and feel like im getting a bad cough!
i kinda think that all the sicknesses are linked in some way? alot of people i know have been sick lately
so has anyone experienced something like this??
https://www.sau.com.au/forums/topic/239918-anyone-been-unwell/
I've been suffering from nausea for the past 2 weeks, feeling real lightheaded and having a loss of appetitite (which leads me to starve then I get even worse and start getting migraines). I left work early again today for this reason. I dont know what it is (definately not the flu), but if it persists for another week I;m definately taking a visit to the doctor for the first time in my life.
Edited by Dani Boi
i went to the docs today! i had to give a stool sample and also a blood sample.. results should be back in the next couple of days!
i have been feeling exactly the same as dani boi and crans.. maybe its a virus going around atm?? hopefully things get better soon
When people say they have the flu generally its just a common cold and they get over it in a few days. If your bed ridden for over a week with huge fever like symtems and you sleep most of the day you have real influenza, generally type a. Once you have had it you really cant get for a long time after as your body finally becomes immune and thats how it goes away. You will then stay immune for a long time after. Thats pretty much what the flu shot does it gives you a tiny dose of the flu to get your immunity up.
Sounds like you have a bad virus not associated with influenza go see a local gp.
Edited by Pattygtst
update- just been to the docs for the results on the blood test.. clear of anything major like hepatitis.. but i did have abnormal liver functions! so i have to have a liver ultrasound 2moro!!
the doc told me there is a virus going around atm with the symptoms like mine.. nausea/vomiting/diarrhea for the first few days and then start developing flu like symptoms such as sore throat/cough/aches! apparently it originated i queensland
Usually I get sick about once, maybe twice a year. This year I've lost count...
Had my usual sickness near the start of winter, then was getting over it. My boss went on holiday to Mauritius, came back to work sick (thanx boss), and I picked it up off him. No-one else did, and I think that was cos my immune system was still a bit low. That made me sick for a few weeks, but thankfully got better just before my holiday to Broome.
In Broome, we sunk bulk piss. Was f**king ace actually. But anyway, I didn't get sick like I did last time I did that & came home, but a few weeks after going back to work I was sick again. Since then I've just got over it (literally a day or 2 feeling 100%), then I've been knocked back down again. I'm at the end of another one now, sinus stuff annoys me sometimes & I cough every now & then but fine apart from that. I'm hoping now it's warming up that will be the end of it. But if not, then I'm gonna have to go to the docs & see if anything to do with work is affecting me, all flour n things like that....
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
