  • Replies 132
whats wrong now????????
nah nothing.. just gotta get another manifold bolt so i can bolt the turbo on. then need some clamps for the cooler and a silicon joiner. an afm...
^^ +1
drive it while you got it :)
i think i may be there only sunday
who else will be?
i have family stuff to do on sat, and the missus is workin sunday so i got a free pass woooot :(
hey guys, im ken, ill be out at gazzanats, ill be wearing a black shirt and on the front it has, mola, on the back it has why be stroked, when you can be BLOWN, ill be there in a v6 supercharged ke70 rollar, painted matt black with centrelines on it, if u see me come up and introduce urself, always nice to meet new people, i have only lived in adelaide for 6 months, cheers, ken
Hmm ... wanna see this car. Sounds like something I would have built some years ago! ;)
was down at vilis for a bit then got a call from my parents , they were in tears so i had to rush home to find out that my dog was at the vets on a drip , old girl isnt doing too well ;)
might come back out later but its weird not knowing anyone :)
do you have any connection with Brentons Mechanical Workshop?
my best mate Adam is the apprentice there and was mentioning a car along these lines
I managed to rock up... just as people were leaving lol
what time everyone leave? i rolled past there but people were well gone by the time i got there :D needed to vent some uni fustrations so a spin was needed
what time everyone leave? i rolled past there but people were well gone by the time i got there :rofl: needed to vent some uni fustrations so a spin was needed
think it was about 8:15-8:20ish.......
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
