well, as the title says,
i sold the 33 today
some 20 yo bought it. 13g cash
hope he looks after it as well as i did,
judging by the way he drove off (even in low-boost) it aint gonna have a good life imo
ahhh well, life goes on, time to start looking at my new home.
https://www.sau.com.au/forums/topic/240011-my-babys-gone/
  • Replies 66
yeah im not gonna say much just in case he comes on here,
but, you know..........................
na damo, new house first mate, may even take extended mortgage for 34. gotta see what the boss (gf) says
https://www.sau.com.au/forums/topic/240011-my-babys-gone/#findComment-4192055
I'm with you mate ... investing in property first. Car second. :P
Hope the mortgage goes well. Once your on top of it, extend it and get a 34 :)
very much agreed, altho with current "economic crisis" im almost tempted just to keep spending on the current car lol
https://www.sau.com.au/forums/topic/240011-my-babys-gone/#findComment-4192118
same, once the housing prices come down a bit i may be inclined to purchase an investment property, probably take an extra 20k on the loan to pay off my car loan so just the one payment comes out. Better start saving :P
Edited by Damo_R34
https://www.sau.com.au/forums/topic/240011-my-babys-gone/#findComment-4192124
i sold the 33 today
:P so he drove it just like you did :wink::)
https://www.sau.com.au/forums/topic/240011-my-babys-gone/#findComment-4192329
cheers all :)
its good to have that extra boost in house deposit,
and with no car expenses, ill be saving soooooo much money!
so its a blessing iin disguise really, hasnt really sunk in yet though :)
wait till summer nights when your all out cruising :blink:
https://www.sau.com.au/forums/topic/240011-my-babys-gone/#findComment-4192565
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
