Hello,
I was just wondering what brand and grade of gearbox oil you people use in your cars? I need to do an oil change. Do most use 75W90 grade? 75W80 grade? In the morning, when it's cold, I have great difficulty in getting the car into reverse (or first). I would like to try a different oil to get the gearbox running smoother in the morning. Once the car warms up, the gearbox is fine...although it can be a little notchy at times.
I have heard that RedLine is very good, but I can't find any. Does anyone know where I can get some here in Adelaide? I don't mind paying for it (cos I know it costs a lot), I just want to try it out.
Cheers.
https://www.sau.com.au/forums/topic/24008-gearbox-oil/
I use the Redline Lightweight Shockproof Gear Oil (it is green) and it is BLOODY fantastic!!! You can also buy an additive so put it in your diff too. I don't know where you can buy it here (someone once said try Autobarn or some specialist performance place on Magill Rd), but I get mine from Trent [email protected] at www.mercurymotorsport.com.au. He is in Queensland but he overnights oil and other parts to me no problems (and he owns an S15, so he is hella cool!).
https://www.sau.com.au/forums/topic/24008-gearbox-oil/#findComment-515969
Clint's right, you can get it from here. I have been meaning to get some for ages, but too lazy to drive out there :)
GREEN FIELDS — Pfitzner Performance
Sales
Phone: 08 8285 2933
Fax: 08 8285 2944
Address:
14a Watervale Drive
GREEN FIELDS, 5107, SA
Email: [email protected]
Speciality: Performance gearboxes, Red Line Distributor
https://www.sau.com.au/forums/topic/24008-gearbox-oil/#findComment-516564
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
