I've recently had a RB25DE head rebuilt, ported and polished.
He didn't polish the Intake ports up much as its best to leave them a little rough.
He also did few other little bits inc. removing some material around the valves in order to help the gas enter/leave the comb chamber.
I wonder if it will lower the compression?!?
I've made the pics smaller they are around 50kb each.
Chris Milton Engineering concentrated on the exhaust ports so when I get some decent pics of the exhaust ports I'll post em'.
https://www.sau.com.au/forums/topic/24026-the-rb25de-head-recoportpolish-pics/
I'll be interested to see the exhaust ports :P
I've just ported my RB25DET head but apart from a bit of smoothing and polishing I left the the combustion chambers alone. I wonder how much benefit there is from de-shrouding the valves ?
They checked out the std valves and said they were in perfect condition so they didn't replace them. He said there was no wear on the valve stem.
It was worth just under $900. Chris had the best price and the most experience with these heads. I gave Adelaide Engine Developments a buzz and with slightly less work done they wanted $1100.
Bl4ck32 also had his head done at the same time so I guess it was a bit of a bulk job.
The head will be going on a 3ltr bottom end soon :P
Yer it was Freebaggin...
You are blowing heaps and heaps of black smoke...
You pulled out of the corner near lonsdale?
I was hoping you were going to give it some stick as I was in the mood, I had just ate a old VH V8 thing with stally that chiped third gear.
I was sitting at the lights behind him he was like laughing with this big smirk probably thinking haha your going to get your arse kicked .
He then stalled it up with his stally but wheel spun through first, he chirp second, I had to short shift second then pinned third pulled out and over took rather quickly with his reving in my ear I clicked fourth and then pulled in front. :P Good ol' RB's and 16psi.
He had a "Only wine comes in 2ltrs" blue sticker on the back window. It was pretty slow for how it idled (rather lumpy) and the stally and gear chirps i.e 2nd and 3rd.
Meggala,
At first I'm going to keep using the stock box until it dies.
It should be ok as the traction won't be there hence tyre width.
I'm going to keep running the 225 50's until I get the RB25DET box in there. Until then.. it will be wheel spin in 4th.. :P
Maybe.. Don't really know but should be fun anyhow.
I'm also going to keep the HD 30% Organic clutch. That will most probably die before the gearbox.
I'm also ditching the Chrome Molly Flywheel and am going to go a balanced std. RB25DET item. I'd rather have the heavier weight of a stock flywheel to absorb the vibrations + the RB20DET clutches are slightly smaller than the RB25DET. I think.. ;)
Yep, it's a rich mixture but has the power so I don't mind, Tim and Shaun's doing.
Good to see you blew that git away! Only have 2 points left on license so have to take it easy for a while.
Good luck with 3L!
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
    • Not sure yet.  Was considering speedtek because it was rated to 800hp, but when I did some research about him I don't think I will go for that🤣 So maybe giken gear set, but I'm afraid it won't be strong enough🙄
