Nice clean black R34 (debadged) number plate XRK ---
So sorry to see... a lot of front end damage. Anyone from here? Both parties looked alright, i would have missed it by a few mins at most.
Strange looking accident though, another car involved (Bluebird?) but I couldn't figure out what happened because it looked like the other car had significant front end damage too. Sorry, no pics.
https://www.sau.com.au/forums/topic/240331-accident-r34-smashed/
speaking of accidents, the news cant seem to figure out what a skyline is?, the news had a soarer crashed over by casino and they called it a nissan skyline, assholes, thats twice in a week.. thats my grudge for the day..lol, and blamed it on street racing too.!!!
no sh*t..the other week when the 180 crashed they called it a nissan skyline...lol even my dad picked up on it..ive taught him well lol
hope every one is alright..god i hate car crashes
Was not a pretty sight was it... looks like the other car might have been coming out of a side road and took out the 34 as both seemed to have front end damage?
my mate messaged me saying he saw a black 34 gtr crashed on Payneham rd and seeing as i was on magill decided to check it out
was a black 34gt that lives 2 streets from me :(
nvm, sounds bad -_- Hope the engine wasnt too badly hurt :(
Edited by Mowbuss
I saw the cctv footage of the soarer crash on festival drive,
Car came down the hill, flying past the carpark entrance, slid out round the corner, overcorrected and hit solid concrete pillar.
Driver looked pretty bad,passenger had to be cut out of the car...
there was a sapol paddy wagon right behind them when they hit but they missed the impact.
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
