Hey all,
Just a quick one - I sold my car the other night, and im considering purchasing an R32 GTR as my next car. I checked one out recently, which was an 89' model. I read the other day on carsurveys.org the following:
"The best thing about the r32 gt-r is that the 1989 models had the race spec rb26's straight from the r32's that were put up against the aussie v8's in 89, all gt-r's built after 1989, including the 1990 r32gtr, were made out of cheaper materials to save money which meant less reliability, other than that I'm an r34 lover, I will have one by the time I'm 24 (I'm 16 now), but any gt-r will do at the end of the day."
Did a quick search of the site to see if anything could shed light on this comment, but didnt find anything to support it either way.
Is there any truth to this comment?
Thanks in advance!!
https://www.sau.com.au/forums/topic/240353-89-r32-gtr-engine-internals/
the earlier R32 blocks had a slightly better (thicker) casting....everything else is the same...except the earlier cranks which had the smaller inferior oil pump drive which is well known.
Edited by DiRTgarage
    • Absolutely could be. I collected data logs from when the O2 sensor was still out and also after I had replaced it so will try to compare them. Pretty confident that the affect is lowered with the new sensor, will check logs at the same RPMs/conditions.
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
