Item: RB26DETT R33
Condition: Perfect, still has all black paint on plenum, very stock motor, stock clutch etc...
Price: $4600, or Will swap for a RB25DET cash my way, (for all those who want to upgrade to a 26) This might save you some money etc...
To Fit: anything you want to put it in
Contact: PM me or post up your offer,
Comments: Rb26dett is in perfect condition, comes with look and computer, pretty much everything, so if you want to swap your rb25 plus chas my way i would be happy to take a rb25det with loom and computer to put into my car,
This engine has 115,000kms on it,
inspections welcome,
Thanks JV
Edited by sly32
https://www.sau.com.au/forums/topic/240626-r33-rb26dett/
Item: RB26DETT R33
Thanks JV
does it come with everything like turbos dump pipes etc
how much cash plus swap for my rb25det pm me
https://www.sau.com.au/forums/topic/240626-r33-rb26dett/#findComment-4203029
Looking at around $2500 and the Neo For the 26, The 26 comes with turbos, loom, ecu,
Obviously this cash adjustment will be more for people with series 2 motors or series 1, depending on K's and condition, etc....
https://www.sau.com.au/forums/topic/240626-r33-rb26dett/#findComment-4220958
hey mate i got a R33 thats got damage with it. just body work
but the engine is all fine just clocked over 100000
and i have the whole car as a complete so i can swap
you the engine and whatever els you might need
then can organise cash my way if need other things or
cash your way if you just need the engine as a complete
thanks
https://www.sau.com.au/forums/topic/240626-r33-rb26dett/#findComment-4231632
thanks
i have a power fc for it as well. and i can swap you the whole car for the
engine as it is not repairable all machanics works just the chassie has been
pushed back
https://www.sau.com.au/forums/topic/240626-r33-rb26dett/#findComment-4231725
  • 1 month later...
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
