Hey guys.
I need a R33 gtst right hand side (drivers) steering rack
If you can help me out, please give me a call on 0415 163 555. Im not sure if i will be able to get on here to check pms etc.
Thanks.
Hey guys.
Thanks.
Toy shop at beresfield in Newcastle, I Just replaced my left steering rack, ill see if i can find a price on my recite.
Spotted a yellow stag last night along Sandgate Rd about 9ish.
Last Friday got a wave back from a silver R33 along Thomas St near twin shells going the opposite way.
Spotted a White R34 Coupe going along Turton Road. I think he waved me at the last second and I did too. Was just a stock one :banana: Not sure if it was a 25GT or GT-T, didn't see the rims clear enough.
spotted white R33 gtst with gtr front bar at newcastle last night near the crown plaza bout 10:30pm. sounded tough
also seen silver 32GTR parked on pacific highway or what ever road it is off king street
Aha yup that was me. :thumbsup: I was looking at your car trying to figure out if it was a 34 or not. It was too late before I realized, hence the half assed wave and hazards :laugh:
Saw a white NA R34 coupe with no wing (green P-plater) in Cardiff this arvo about 4:45 PM. It had grey rims with a silver lip I think.
Came up next to him a couple of times and was going to wave if he looked but he never looked across :)
Seen both you guys go through crossroads :(
Spotted a marone r33 gtst wyong road tonight
yeah that was me ......... i see didnt get time to wave back
yeah seen nick *hot34* at budge coles the other day
seen TRIPA *White 33GTS-t in buff point yesterday
Edited by BB81DO
yesterday at lisarow spotted a white R34 gtr saw ya wave at the last second lol... also got some loving off a white 34 gtt at the lights at tuggerah station lol mick :banana: ... this morning another white 34 gtt parked at the roadworks at ourimbah, bfn *** sumtin, looked really nice!
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
